wastegates vs. BOV
Old Oct 7, 2001 | 05:58 PM
Pinfield357's Avatar
wastegates vs. BOV
can someone tell me the difference between a wastegate and a blow off valve?
thanks
pinfield
Old Oct 7, 2001 | 06:12 PM
AJC13B's Avatar
10.32 @ 133
A blow off valve vents excess air in the inlet between the turbo and the throttle butterflys.
It is spring loaded and also has a vacuum line attached to the plenum AFTER the throttle butterflies so when the throttle is closed and there is a vacuum behind the throttle it helps to suck the BOV diaphragm up along with the spring loaded tension pushing it up and it vents the excess air.
A wastegate vents excess exhaust gas out and around the turbo exhaust wheel keeping boost down. You can have either an internal wastegate which is a part of the exhaust housing (99% of OEM turbos have an internal wastegate) or you get the external ones such as Garrett, HKS, Trust etc etc. These are also spring loaded and work similar to a BOV. When the air pressure gets to a certain level the spring is forced open and the exhaust is vented.
Hope this helps.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
GKW
Sep 28, 2015 04:34 PM
