Which intercooler to get?
Old Nov 28, 2003 | 10:17 AM
hondah8er's Avatar
mazdaspeed 3 coming soon
Cool Which intercooler to get?
Hey guys. I have a question for you. I have an 85 rx-7 with a streetported S4 13BT, 60-1 turbo, microtech, hks manifold and wastegate, bosch fuel pump, etc you get the idea. Basically I want to replace my intercooler and have found a place that has good deals locally to me. Anywho, I'm going to list 2 different sizes (one med size, one large) and was hoping if some of the more knowledgeable guys can give me some advice for my current application. When its all tuned I'm aiming for about 370 rwhp give or take at around 12 psi. Possibly 400 but not more for sure.
Which intercooler dimensions etc would be more fitting to my goals.
medium size one:
Flows up to 700 CFM and more than 500 hp.
Core Length : 22" (550mm)
Core Height: 9" (230mm)
Core Thickness: 3" (75mm)
Inlet Size: 2" o/d (50mm)
Outlet Size: 2.5" o/d (65mm)
"End to End" Length: 30" (750mm)
or....
Large size one:
Flows up to 900 CFM and will support over 650 hp.
Core Length : 24" (600mm)
Core Height: 12" (300mm)
Inlet Size: 2.5" o/d (60mm)
Outlet Size: 2.5" o/d (60mm)
"End to End" Length: 31" (775mm
Thanks for any replies and comments. The current beat up one I have now has a 2.5 inch core I beleive and is 15 inches long (total length) and about 10 inches high. This supported 271 rwhp on the stock turbo about 2.5 years ago.
Old Nov 28, 2003 | 01:02 PM
hondah8er's Avatar
bump
Old Nov 28, 2003 | 01:27 PM
setzep's Avatar
I'd go for the bigger one or witch ever one you think will fit better. Take in account the inlet and outlets
Old Nov 28, 2003 | 01:35 PM
hondah8er's Avatar
setzep i know you have a 13bt 1st gen also. what are the dimensions of yours and do you have pics of it mounted?
Old Nov 28, 2003 | 01:54 PM
88fc3sw/HX83's Avatar
Im selling my XS Engineering "GTR" core intercooler, PM me if you're interested. 24x11x3
Old Nov 28, 2003 | 02:11 PM
setzep's Avatar
14" tall 15" wide and 3" thick. 2.5" in and 3" out. I'd show you a pic but the search function isn't working for me right now. I have a few pic's up on the forum somewhere.
Lets see some pic's of the "GTR" IC
Old Nov 29, 2003 | 09:16 AM
email me at we.online@comcast.net, the pics are too big to post on here
Old Nov 29, 2003 | 11:47 AM
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/v-mount-intercooler-238894/
It's near the end of that thread
Old Nov 29, 2003 | 02:05 PM
setzep's Avatar
It looks kinda long, I wonder if it will fit in a FB?
Old Nov 29, 2003 | 06:30 PM
Total length is about 29" (endtank to endtank)
Old Nov 30, 2003 | 12:02 AM
setzep's Avatar
where is hondah8er?? abandon his thread?
Old Nov 30, 2003 | 12:07 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
The large volvo one fits like a glove, all you have to do is loosen the belly pan, fit it into place and tighten the belly pan.
Check Ebay for the demensions. But I think the big one will fit.
Old Nov 30, 2003 | 12:23 AM
setzep's Avatar
So what did you mount the IC to once you put the belly pan back on?
Old Nov 30, 2003 | 12:45 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
i may end up with a liquid to air...
if i do this, i'll keep the stock top mount (on my 87) and have an aluminum "box" welded around it. i've got a honda goldwing (yes, the motorcycle) radiator with a fan that will fit up front perfectly....all i really would need is a pump and a box for a surge tank/ice box....
that may work just as well if not better than lots of the aftermarket intercoolers, but it will only cost between $150 and 250 to build...
something to think about
Old Nov 30, 2003 | 08:57 AM
setzep's Avatar
but the flow capabilities will hinder HP with a stock IC.
Old Nov 30, 2003 | 01:20 PM
you're right about that.
but i was thinking they wouldn't hinder it enough to not justify the bang-for-the-buck you'd get out of it.
i've seen that setup make 425 to the wheels when properly tuned.
i'm only looking for about 300 now and maybe another 50 or so later on, so it may be the thing for me. but i guess if you're into the super-mega numbers, you'd be better off with a higher flowing cooler. it's all give n take and what you want for what you can afford i guess.
Old Nov 30, 2003 | 02:11 PM
PPC-Racing's Avatar
size is secondary to ther TYPE of IC you are using.. a bar & plate flows much higher then a rod &fin style, less loss across the body of the IC, so you effectively go with a smaller B&P style IC and maintain the same or higher flow rates, it's generally reccomended that if you plan to go to 400hp then a B&P style is better then a R&F style.. the one advantage of a R&F style is that it's cooling cababilities are better, ( this is also the reason for the greater pressure drop across the R&F IC as well.. )
Old Nov 30, 2003 | 04:51 PM
hondah8er's Avatar
Nope...been busy this weekend. I tried to post a pic of the intercooler i'm looking at but the damn forum wont let me post it
Old Nov 30, 2003 | 04:54 PM
hondah8er's Avatar
go to www.yonaka.com setzep and you will see the med size one and large size one. Opinions are welcome.
Old Nov 30, 2003 | 05:54 PM
setzep's Avatar
I think those are better suited for wider cars. It looks like the in/out on those won't work on a FB well.
Old Dec 1, 2003 | 09:21 AM
hondah8er's Avatar
hmmm... I see what u mean about the width and especially the in/out. I think with some thinking it could be made to work though.
What about this one ? Its a spearco core and is more or less the same but about 5 inches shorter....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2445965443
Old Dec 1, 2003 | 07:08 PM
setzep's Avatar
That thing looks ugly. Look how the in/out's basically blow into a box then the air has to travel down the long tubes. I would think it would have good temperature drop but higher pressure drop.
Old Dec 1, 2003 | 07:26 PM
setzep's Avatar
Here is a pic of mine. See how the in/out is at the top vs the side. Also consider what size the in and out is.
Old Dec 1, 2003 | 09:43 PM
hondah8er's Avatar
Setzep that intercooler you have looks just right for a 1st gen. Where did you get it and how much $$$? Pm me if you like
Old Dec 2, 2003 | 07:47 PM
setzep's Avatar
It look's just right because it was made for a FB/SA.
PM RiceRacing. I got it from rx7passion but he bought it from riceracing.
