oopinions on ebc gren stuff brake pads
Old Nov 27, 2003 | 06:39 PM
PwRFreaK's Avatar
hi i was looking at getting these for my car, i plan to road race it once every 2 months and want a pad i can run on the street and not have to change for the track. supposedly they dont dust very bad and are street pads does anyone know how they hold up??
thanks in advance
Old Nov 27, 2003 | 10:34 PM
REFLUX's Avatar
www.v8less.com
some people love'm
some people HATE'M
Everyone seems to use Hawk & loves'm..........
Old Nov 28, 2003 | 01:44 AM
Cossie's Avatar
good for road...
dont think it's that great for track...
Old Nov 28, 2003 | 10:19 AM
They are a very good "dustless" street pad. They will never fade on you, even on the track, BUT they only last~1 hour +/- under race conditios. The EBC Reds last a little longer, but same comments. I would say Carbotech Panthers as a dual use pad, or XPs as a track pad. The XPs are fantastic, but have to be warm to work. Personally I would avoid all the Hawk pads for your application. There are some performance Friction pads that are very good, but $$$, and I prefer the XPs. Carl
Old Nov 28, 2003 | 01:20 PM
maxpesce's Avatar
Ex fd *****
If you are Serious about the track - Then use track specific pads - If you mus drive the car to the track Change them at the track, it only takes 15 min once you do it a couple times. Just use compatible pads (like Hawk HPS for the street & Hawk Blue for the track or Carbotech Panther&XP, etc.) so you don't have to resurface the rotors each time! I also found that EBC Green's, while very grippy and fade resistant only last one day at the track (in my case approx 80 min, in 4 20 min sessions at Streets of Willow Springs took them from new to less than 15% remaining) I did 3 20min sessions at Buttonwillow (full course cw) w/ Hawk HPS that had been used 5k mi on the street and still had 50-60% pad left however they did fade after 3-4 hard laps requiring 2 cool down laps in the middle of a 20min session.
Old Nov 29, 2003 | 03:34 AM
BNA_ELLIS's Avatar
The worst pads I have ever put on my rx7. I find no gains over stock pads imo and they don't last. Mine were worn to the metal in justunder 2,000 miles of street use. Yes I do drive hard but not that hard.
rgds
Old Nov 29, 2003 | 09:31 AM
SleepR1's Avatar
EBC Greenstuffs from Tire Rack. Great pads for street and open track events. The Greenstuffs have excellent bite when warmed up, and are pretty much fade free when used within their operating temps. Overheat them, and like any pad material, the Greenstuffs will fade. Greenstuffs have sharpened my use of the brakes; I use them SPARINGLY--just enough to slow the car for turn-in.
On the street, the Greenstuffs hardly dust at all, and provide good cold bite.
If you plan to open-track every other month, the Greenstuffs will work fine for you.
My other suggestion is the stock Sumitomo '99 Type RS/RZ brake pads from Mazdaspeed Motorsports Development. Similar performance to the Greenstuffs. I've found that each pad leaves a slightly different pad film, so you might get some pad shudder (during open-track) when switching between Greenstuffs and Sumitomo Type RS pads.
Please note my opinion comes from my experience with '99 Type RS brake rotors and calipers all around on my FD3S. Other opinions may vary based on the FD3S owner's braking system compononents (such as stock US spec FD3S calipers/rotors, or upgraded front brake rotors/calipers only with stock US spec rears).
Old Nov 29, 2003 | 07:48 PM
TheTwinTurboRX-7's Avatar
I have the Greenstuffs in my circle track Honda, I got them because a pad that has to heat up is uesless to me as I don't have time to warm them before they have to be used. They stop better than OEM and I have had no complaints. Mine lasted all season just fine but they are all short races.
Old Nov 29, 2003 | 10:31 PM
SleepR1's Avatar
What is a circle track Honda? Just curious?
Old Nov 29, 2003 | 11:09 PM
It would be a Honda that I race on a paved oval track. 3/8 mile
Old Nov 30, 2003 | 08:55 AM
SleepR1's Avatar
Ahh...oval-track racing Honda...COOL
Old Nov 30, 2003 | 10:13 AM
Thanks, I race in an all four cylinder class, that is mainly dominated by the H. When in Rome, do like the Romans.
Old Nov 30, 2003 | 03:29 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
i really like all of EBC's pads. i run the greens on the street and one click up from them for track days. the greens, like any high performance street pad, can be made to fade at the track. no surprise. for fast street performance they stop right now, make no noise or dust and your rotor looks like a million bucks. i have had no wear problems with them on the stock front or the AP setup that i have run for the last few years.
howard coleman
Old Nov 30, 2003 | 09:38 PM
diyman25's Avatar
RE for life
EBC GREEN
never use it before, BUT It only last two track day on my friend's 300ZX. complete worn out to the metal,
Old Dec 1, 2003 | 06:39 PM
SleepR1's Avatar
Re: EBC GREEN
300ZX is 3500 lbs with brake rotors same sized as US spec FD3S. This means the rotors need to heat sink 750 lbs more momentum. That extra weight translates into more heat, which will melt most any brake pad material. Your friend needs 14-inch diameter x 3-inch thick brake rotors to help with heat sinking all that kinetic energy
Old Dec 2, 2003 | 01:08 AM
Houdini's Avatar
didn't like the EBCs at all. Ate through them on on an open track event under medium braking. I put in HP+ and I love them, although I haven't run them on a track event yet.
Old Dec 2, 2003 | 09:48 PM
PwRFreaK's Avatar
anyone run the reds? those seem like a better choice
Old Dec 2, 2003 | 10:38 PM
SleepR1's Avatar
Red Stuffs were junk. Ran through them in a day @ an open-track event. Green Stuffs were much better.
Old Dec 2, 2003 | 10:39 PM
SleepR1's Avatar
Looks like the opinions differ so much, that you'll just have to try EBCs for yourself, and draw your own conclusions...
Old Dec 2, 2003 | 11:44 PM
Carl Byck's Avatar
Mad Man
Manni, I am suprised at your experience(red vs green). Given the no fade, I wonder how the "endurance pads" would do from EBC? Moving forardv I have never heard bad about the panthers, only that some felt PF was better. My rotors are perfect after three full weekends(~2.5hrs/weekend), and I have almost no rotor wear, and still have 65%+ pads. As I said, I can out brake an occasional track day guy easily in my FC, VS his 2003 996TT, and I can easily brake with a 03 ZO6(experienced) from ~130 to 50. Carl
Old Dec 3, 2003 | 11:11 AM
SleepR1's Avatar
Dunno, maybe I had a bad batch? Roasted the Red Stuffs down to the backing plate. It was ugly! Also tried the CB Panther Plusses. Nice pads, until the price increase
