How to make your window regulators last longer
Old Nov 27, 2003 | 12:08 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
As you may know, the window regulator mechanisms on 1st gens. are prone to wearing out pretty quickly. This is largely due to the fact that the shaft is not bushed at it's outboard end, but is merely a pin sticking through a punched hole which becomes oblong in time, allowing the gear to cant with respect to the rack. This not only wears the teeth on the rack unevenly, but also causes binding, and slipping.
Here's what you do:
Remove the window crank handle and turn it 180 degrees and reinstall it.
Pretty simple, huh?
Do this every six months or so, and your window regulator will last longer.
Old Nov 27, 2003 | 02:12 PM
gonzz's Avatar
cool, thanks
Old Nov 27, 2003 | 02:40 PM
theweasel's Avatar
Hey, another springfield guy!
Old Nov 27, 2003 | 06:20 PM
RotorMotorDriver's Avatar
Seven Is Coming
Crank handle? Whats that? .
~T.J.
Says the driver of a GSL, and owner of only one GS of five RX-7s
Old Nov 27, 2003 | 11:08 PM
rotarydankus again's Avatar
i pulled mine and welded a washer on the back, case hardened too steel, fixed foreeva, trev
Old Nov 28, 2003 | 11:03 AM
Wankelguy's Avatar
Foreeva is a long time.
Old Nov 28, 2003 | 11:19 AM
j9fd3s's Avatar
Community Builder
it also helps to grease em, so its not so hard to go up and down
Old Nov 28, 2003 | 02:59 PM
bliffle's Avatar
Next time I take a regulator out, instead of putting in the $150 replacement I'm going to bush the critical points. There's got to be someway to convert those dudes to sintered bronze oilite bushings.
B
Old Nov 30, 2003 | 12:06 AM
slowautoxr's Avatar
autoxr/rallyxr
Greasing all the moving points does wonders. It also helps if you don't force your windows up or down i.e. don't put a side load on the handle - you just want to rotate it.
Old Nov 30, 2003 | 12:51 AM
jsinrx7's Avatar
yeah, spray lithium grease is the sheeot for this.
Th0m4s
Feb 26, 2019 02:04 AM
Rotospectre
Mar 28, 2018 03:33 PM
bURGRotary87
Aug 19, 2015 03:54 AM
