toe-in?
Old Nov 22, 2003 | 02:00 PM
grantmac's Avatar
toe-in?
I was just looking in my shop manual and I happened to notice that the FB comes stock with 3mm per side of toe-in, wouldn't this make it handle really heavily with slow steering? Also wouldn't it be harder to turn the wheel with the manual steering? I could be going off on the wrong track here but I need to get my alignment done and I want to see it I can make it handle any better while I'm at it.
Thanks,
Grant
P.S. Ever since the carb cleaner and new plugs she's beem running like a dream, and I got her to idle for the first time last night!
Old Nov 22, 2003 | 08:31 PM
brianw's Avatar
Mazda did a pretty good job setting these up but if I were you I'd do a search on mazda factory raceing or something, see if I could find some specs of a race version maybe. Or maybe someone here knows. PM me if yoy find anything cause I have to get an alinment also.
Old Nov 23, 2003 | 09:47 AM
Rx7carl's Avatar
Airflow is my life
If your running the stock rubber bushings in the suspension you need a little toe in. when the car is moving the bushings will deflect and the toe will decrease. Caster is what determines the amount of steering effort needed to turn the wheel. Most alignment shops will only adjust toe, as caster camber on our cars is a bit of work, and usually they wont deviate from factory specs [prolly for insurance reasons].
Old Nov 23, 2003 | 12:17 PM
boosted12a's Avatar
I no nothing
so, if you have polly bushings, what do you suggest for toe?? hmmmm? you dancing bannana FREAK?
Old Nov 23, 2003 | 01:00 PM
grantmac's Avatar
So if I get some more castor dialed in the steering will take less effort? And if I go with better bushings I can kill some of the toe?
Thanks,
Grant
Old Nov 23, 2003 | 03:38 PM
Rx7carl's Avatar
Airflow is my life
Jake, since the poly bushings have less deflection, you need less toe in. maybe 1/8-1/16". And your starting to sound like Sterling BTW.
More caster= more steering effort, easier self centering, and more camber gain.
Old Nov 24, 2003 | 03:32 AM
boosted12a's Avatar
I no nothing
he,he.....i see. makes sense to me.
ultrataco
2nd Generation Non-Technical and pictures
Dec 10, 2009 08:14 PM
ray green
Sep 17, 2009 02:58 PM
TheLeech
Sep 25, 2004 04:16 PM
