Whats the difference: Pacesetter or Racing Beat?
Old Nov 21, 2003 | 07:02 AM
John64's Avatar
What?
Question Whats the difference: Pacesetter or Racing Beat?
What is the difference? I have a two year old muffler that will make the transition over to my new system. I'm looking at the Bonez converter system(yes it will be a street car) and what to update the header at the same time. The pacesetter is 241.00 armor coated and the RB is 198.00 straight up. What would I have to do to the header to put th O2 Sensor back in?
Thanks for the help
John
Old Nov 21, 2003 | 07:55 AM
onepointone's Avatar
i say what i want
ive heard REALLY shitty things about pacesetter. i remember reading about some guy that had to completely cut apart the header because they welded it up wrong (something about it being completely backwards. ive also heard they just in general dont fit good. racing beat on the other hand, has been in the business for a LONG time, and i will tell you, when i got mine i was impressed with the quality. bolted on and fit perfectly. ive had it on for over a year, and i have nothing but good things to say about it.
Old Nov 21, 2003 | 08:30 AM
Gregs's Avatar
its simple
pacesetter= JUNK
racingbeat= THE BEST
Old Nov 21, 2003 | 09:37 AM
Rx7carl's Avatar
Airflow is my life
RB uses heavier gauge steel, better fit and finish, equal lenght tubes, but sharp bends right out of the housing. Pacesetter, lighter steel, un equal length tubes, some finishing required for good results (the stud holes need to be opened up and the collector needs some grinding inside to it out), but has straight outlets from the housing before the turn. This is for the 12A headers. I've never messed with 13B's but I know that Pacesetters 13B header is a one piece. I am speaking as someone who has had both a pacesetter and 3 rb headers. NOT someone just regrugitating what they heard from someone else. I won my CSP championship running the pacesetter if that helps at all.
Bottom line- the rb is a better built header, but the pacesetter isint the pos everyone says it is. It just needs a little work. Oh and I wouldnt use the armor coat. I doubt itll hold up to the rotary exhaust. Go with jet hot 2000 if you want a coating.
Old Nov 21, 2003 | 12:05 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
What about the third option?
You know, the one nobody ever mentions, Mind Train.
I've never used one so I can't speak for it's durability or fit, but it sure looks like it would flow pretty well.
Has anyone used one?
Old Nov 21, 2003 | 12:20 PM
RRTEC's Avatar
Rotartist
Night and day...that's the difference. I had a pacesetter (monza) it leaked around the ports and made the car smell like fumes..now i only use rb...they are worth the extra $..my .02
Old Nov 21, 2003 | 12:21 PM
Random's Avatar
Good results with the Mindtrain from posters on the fb email list. Built like the proverbial brick shithouse, but priced to match ($$$).
Old Nov 21, 2003 | 12:33 PM
Rx7carl's Avatar
Airflow is my life
Does Mind Train make headers? Pic? specs?
Old Nov 21, 2003 | 02:24 PM
Pele's Avatar
Right near Malloy
Originally posted by Gregs
its simple
pacesetter= JUNK
Damn you! I was gonna say that!
On a side note, can you buy Mindtrain factory direct like you can with Racing beat? They don't appear to ahve a web page, but Rotary Performance (Of Manassas, Virginia... Not Garland, Texas.) sells them.
http://www.rp-performance.com/
Old Nov 22, 2003 | 01:15 AM
Rotor13B's Avatar
Wassup!!
Also you can get the RB header w\O2 sensor bung installed.
