Look what 10 years of sunbaking can do to a speaker...
Old Nov 21, 2003 | 12:27 AM
WaLieN's Avatar
Call me gramps!
Red face Look what 10 years of sunbaking can do to a speaker...
Well, my center Bose speaker wasn't working, so I bought a new amp. That didn't work, so I checked out the speaker.
Does anyone know where I can score a new center Bose speaker?
Old Nov 21, 2003 | 12:52 AM
Flyrx7's Avatar
Money Pit
Wow! and that one's in good shape!
Makes you wonder if it really does add any soundstage at all. Personally, I'd can the Bose setup and go aftermarket, you'd get much better sound and you could gain more hatch space by getting rid of the snake.
Regards,
Frank
Old Nov 21, 2003 | 01:01 AM
WaLieN's Avatar
Call me gramps!
Makes you wonder if it really does add any soundstage at all. Personally, id can the Bose setup and go aftermarket, you'd get much better sound and you could gain more hatch space by getting rid of the snake.
Regards,
Frank
I would do that, but I already got one of the speakers repaired, so only the center speaker isn't working. I'm not *too* into car audio, so I figure I'll just stick w/ the stock setup.
Old Nov 21, 2003 | 03:55 AM
InsaneGideon's Avatar
Still on 1st engine
You could rig up something like the speaker on the bottom of this page:
http://www.eclipse-web.com/products/av/av8533.html
I'll be installing one of Flyrx7's center speaker triple 52mm gauge pods--when I get a hold of some gauges. This 2" speaker could possibly fit in one of the pod spaces. :P
Old Nov 21, 2003 | 09:31 AM
Flyrx7's Avatar
Money Pit
Any idea on the price of that speaker?
Nice headlights in the avatar BTW!
Frank
Old Nov 21, 2003 | 06:42 PM
WaLieN's Avatar
Call me gramps!
I was thinking of setting up a different speaker, but I don't know how much the stock Bose amp puts out.
Old Nov 21, 2003 | 07:34 PM
Still on 1st engine
Frank, I dont know the price, but in general, Eclipse == $$$ Even though you probably get what you pay for.
I don't know the power specs on the center channel amp either. It really couldn't be much. Mine is in perfect shape and it's VERY faint. It's only meant for mid-high freq "center fill" to elevate the staging a bit.
Old Nov 21, 2003 | 08:47 PM
nillahcaz's Avatar
you are missed
trust me eclipse ==
you can get a pair of 3.5" from half.com for $35
Old Nov 21, 2003 | 09:02 PM
Larz's Avatar
Potato Love
Eclipse has made some of the best car audio products I have ever owned.
Old Nov 21, 2003 | 09:10 PM
WaLieN's Avatar
Call me gramps!
Originally posted by nillahcaz
trust me eclipse ==
I think that'll require some cutting of the stock bracket, if I were to use a larger speaker.
Old Nov 22, 2003 | 12:27 AM
Flyrx7's Avatar
Money Pit
The thing to watch out for with Bose speakers is not the power handling but the OHMS they run. Most speakers are 4-8 OHMS but Bose are like .5 or 2 ohms. That puts alot of strain on the Bose amps when your running more resistance on the speakers. So, if you get anything other than a Bose replacement speaker for the Bose amp you're looking for trouble. That is why I recomend a REAL system, something that runs on normal power and resistance, like 99% of the stereo world does.
Frank
Old Nov 22, 2003 | 01:33 AM
Still on 1st engine
Oh yea, Eclipse's stuff IS awesome! But how much will that little 2" speaker be?
Hmm.. My non-bose system in my R2 has the center channel speaker, but I wonder if mine is 4ohm like the rest of my speakers. The center speaker amp is shared among the different models. Maybe they decided to make this one "standard" for this reason?
I'm fairly sure a higher impedance speaker will pull less current, less power, and also put out less sound on a given amp & signal. If the replacement had more impedance, it'd effectively have it's volume turned down in relation to the other speakers. It's faint enough as it is...
Sheesh. Walien, just buy on of Flyrx7's center speaker pod and forget all about this!
Old Nov 22, 2003 | 03:41 AM
DJ Kontakt's Avatar
I would go with that eclipse speaker. It shouldnt be more than $20 in the right place on the web...
That speaker is so beat it looks like something out of a first gen :P like mine
Old Nov 22, 2003 | 06:36 AM
WaLieN's Avatar
Call me gramps!
Frank
That's what I was worried about... though, I only need *one* more speaker until this "OEM" system is complete. I'm too far into this Bose journey to turn back now. I think I'll call up carstereohelp.com and see how much they'll send a replacement speaker for. I'm sure it'll be under $50 shipped, seeing as how they repaired my other speaker for ~$30.
[edit] I found some useful information saying that the Bose Center Ch. is actually used on all of the FD models, and the speaker is ~4ohms.
http://www.scuderiaciriani.com/rx7/stereo_upgrade.html
I don't think this would make it *too* difficult to find a replacement speaker, should the need arise.
Old Nov 22, 2003 | 09:54 AM
Flyrx7's Avatar
Money Pit
[i][edit] I found some useful information saying that the Bose Center Ch. is actually used on all of the FD models, and the speaker is ~4ohms.
I don't think this would make it *too* difficult to find a replacement speaker, should the need arise. [/B]
That is interesting to know. Makes me wonder why however, as Bose's big thing has always been the lower resistance drivers and amps. I wonder why they would put a 4 ohm unit in with there own, seems like the variation would be more difficult to engineer a proper soundstage. Weird.
Frank
Old Nov 22, 2003 | 04:32 PM
WaLieN's Avatar
Call me gramps!
Frank
Yeah, I thought that was somewhat odd as well. The rest of their speakers are of low resistance, yet one is 4 ohms.
Old Nov 23, 2003 | 12:42 AM
DJ Kontakt's Avatar
Flyrx, it is reallly weird that that speaker would be 4 ohm. BUT. Maybe this explains it.
Running more resistance on the bose amp will put LESS strain on it. the amplifier will put out less power with more resistance in the speaker.
If you put a normal bose amp, I have heard they are 1 ohm, with the 4 ohm center speaker, it would get 1/4 the power. So it wouldnt be very loud, and would just serve its purpose to fill in the hole. Such a cheap way to work it out that way, but effective.
Old Nov 23, 2003 | 01:46 AM
Still on 1st engine
That speaker and the center channel amp are on the non-bose system. I imagine Mazda first placed the speakers and chose components for the non-bose system when designing the car. Probably later in the design, they told bose to do their thing... which resulted in the wave tube and side speakers & amps. They probably just left the center speaker alone.
If I were designing a system, the only reason I'd use 1ohm speakers is because of the 12v supply voltage.
Here's what I mean:
Say you want to put out 100W peak (instantaneous power, not RMS or anything, for simplicity).
P=V^2/R. Solving for R, R=V^2/P=(12V)^2/100W = 1.44ohm. [I have to stress that we're ignoring a lot of other factors.]
This means, if you can only supply 12V to the driving transistors/tubes/whatever and you want to run 100W peak, you can't use a load bigger than 1.44ohm, since you can't drive it with more than 12V.
The reason a car audio amp can run 4ohm is because the amps have switching DC-DC converters to up the supply voltages to the +/-50v range.
By running the low impedance 1ohm speakers they can get more power than a 4V and probably avoid using a DC-DC converter. This can reduce part-counts and avoid DC-DC converter noise & supply problems.
The center speaker channel is probably only a few watts, so running a 4ohm speaker isn't a problem, and they can choose an off-the-shelf part from a speaker manufacturor that comes with a 4ohm voice coil.
Old Nov 23, 2003 | 06:46 PM
I have a 93 R1 and was curious if my rx-7 has any internal amplifiers?? I and if so where are they located on the car. So far all the wiring I have done on the stereo I haven't noticed or seen an amplifier.
Old Nov 24, 2003 | 08:24 AM
WaLieN's Avatar
Call me gramps!
Your center speaker is powered by an external amp.
If you wish to remove it for some reason, go here... http://www.carstereohelp.com/stereor...RX7FTwtAmp.htm
Old Nov 27, 2003 | 10:04 PM
thanks WaLieN but when I bought the car(1993 R1) there was no center speaker in the dash.....but there was a plug for the center speaker. Does that mean i still have an amplifier for the center speaker? And is there anything else(amps/crossovers) in the R1 that I should know about. Do all 3rd gens have a center speaker amp? And if I decide to put an aftermarket amplifier to my front speakers(using the factory wiring harness behind the radio.....because I cant run a wire through the door harness) would that be ok.....? Would the factory wiring hold up to alittle bit of juice and would it hurt the center channel amplifier?
Thanks for all your info
Old Nov 27, 2003 | 10:41 PM
911GT2's Avatar
The Power of 1.3
Thats exactly why I'm replacing my entire sound system real soon.
Old Nov 28, 2003 | 08:54 AM
WaLieN's Avatar
Call me gramps!
Yes, all US FDs should have an amplified center speaker. Though, they vary between the "base/R1" and the "touring" models (at least in 93s). The base and R1 have a different amp/speaker than the Bose system.
You said you wanted to add a different amp, but I would really question where you would want to mount it. Also, from what I hear, the center speaker isn't worth that much trouble.
Old Nov 28, 2003 | 08:34 PM
Still on 1st engine
Hmm... I don't recall anyone saying the amp was different.
Old Nov 28, 2003 | 09:28 PM
WaLieN's Avatar
Call me gramps!
Non-Bose
Bose
