removing 5th and 6th ports....why?
Old Nov 18, 2003 | 10:08 PM
Sk8r_dude's Avatar
Zoom - Zoom...
what does removing the ports on an se do for you? (search didn't help) whats the point? what kind of hp gain is there, and how do you do it?
Old Nov 19, 2003 | 11:46 AM
itzweapon's Avatar
6 ports
from my understanding.. the 6 port motor works kinda like a vtec system on a honda motor.
at low rpms, the 2 additional ports are closed which in turn have some effect on the dynamic chamber/intake air velocity. I had to remove the "6 ports" when I bolted on my turbo setup. I was told that, with the "6 ports" removed.. it helps top end.. but you loose a little power in the lower RPMs.
Old Nov 19, 2003 | 03:30 PM
Sk8r_dude's Avatar
Zoom - Zoom...
does it do the same as pineapple sleeves?
Old Nov 19, 2003 | 04:16 PM
hornbm's Avatar
FD > FB > FC
The pineapple sleeves are a replacement for the stock 5th and 6th port sleeves. The sleeves are there for a damn good reason, and you will gain very little to anything in your high end. Also when you yank them out you can kiss good bye to you lowend. Seriously we dont have much of a low end to loose anyway.
Also the reason why turbo motors are four port, is because the engine is force fed rather than naturally. With the engine force fed you can have much larger ports without worrying about too much of a loss on the bottom end.
Anyway, KEEP THOSE 6 PORTS IN!
Old Nov 19, 2003 | 04:57 PM
XLR8's Avatar
If the engine is an SE then you can remove them or wire them open and still notice little loss at low end. GSL-SE engines had the heaviest rotors of any rotary and gives them an amazing amount of low end. If your going carby then I would remove.
Good luck
Old Nov 22, 2003 | 01:08 AM
Sk8r_dude's Avatar
Zoom - Zoom...
im staying efi, should i get the pineapple sleeves?
Old Nov 23, 2003 | 01:49 PM
hornbm's Avatar
FD > FB > FC
wouldnt hurt anything. Some people say it helps alot, some people say it does nothing. Just by the looks of it, its got to make some kind of an improvement.
Old Nov 23, 2003 | 04:45 PM
gsl-se addict's Avatar
Super Moderator
Before desciding on the pineapple sleeves, you should first read some of the threads on this site about reports of some of the pineapple sleeves coming apart and destorying the engine. I believe that the was just for the inserts, but I would check it out first before desciding. I personally have not tried them, but I bet that you should be able to at least get some gain with them. I do recommend that you do keep sleeves of some kind in for a NA setup.
Kent
Old Nov 23, 2003 | 05:10 PM
hornbm's Avatar
FD > FB > FC
yeah it was just for the inserts that you do yourself. If you send your sleeves to pineapple, you'll be fine.
Old Nov 25, 2003 | 09:54 PM
Sk8r_dude's Avatar
Zoom - Zoom...
any idea how much it costs for pineapple to do it?
Old Nov 25, 2003 | 11:19 PM
hornbm's Avatar
FD > FB > FC
I think it was 50 bucks plus core.
Old Nov 26, 2003 | 03:16 PM
Sk8r_dude's Avatar
Zoom - Zoom...
hmmm....considering it...
Old Nov 26, 2003 | 03:51 PM
purple82's Avatar
Absolute Power is Awesome
Or you can send me 50 bucks and keep your sleeves and have the same result, except I'll be happier. PM me and I'll give you my PayPal address.
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
Steelwheelz
Sep 15, 2015 03:22 PM
risingsunroof82
Sep 7, 2015 01:11 PM
