Choke
Old Oct 5, 2001 | 09:12 AM
lindr6's Avatar
Choke
Just out of curiosity, What RPM does your car run at with the choke fully pulled? What Idle RPM do you guys all have?
Old Oct 5, 2001 | 09:31 AM
cpt_gloval's Avatar
KARATE EXPLOSION
with the choke engaged fully, my car runs at about 2500rpm. i idle between 750 and 900, depending on how my car feels that day.
Old Oct 5, 2001 | 02:12 PM
ReX_Teen's Avatar
Right @ 2500-- Depending on the wheather I idle around 850 and 1000 rpm's. On a stock 12A-
Old Oct 5, 2001 | 06:35 PM
DONNA's Avatar
same here 2500 and 8 /950, when warmer up, but gosh it took a long time to work out the bugs to get it there,,,,knock on wood,,,
Old Oct 5, 2001 | 11:29 PM
Pittdp's Avatar
With the choke out all the way my engine runs at 2500RPM Howerver the owners manual tells me that I should let it warm up at 2000. Once it is warm it runs around 750 - 950 RPM.
Old Oct 7, 2001 | 02:33 AM
Jeff20B's Avatar
Lapping = Fapping
I never need to pull my choke out all the way. I have it pulled mostly out while cranking, then I push it in untill the RPMs go to about 1500 or 1000. Then I start driving slowly untill it warms up. I never wait till it pops in by itself. There's really no point. If it idles above 500RPM, I'm just fine so I push it in manually. I usualy idle between 800 and 1000 depending on the oldschool carby's mood (I can kick it down to 700 or lower sometimes depending on the oil temp). Warn carb butterfly bushings are fun to play with.
Hipsiguy
Jan 13, 2016 01:08 PM
