carb ?
Old Nov 17, 2003 | 05:08 PM
boondocksaint's Avatar
carb ?
anyone here know of a restrictor plat under the carb? and if so can it be removed? any h.p gain? appreciate the response. did a search under "restrictor" but nothing usefull
Old Nov 17, 2003 | 08:17 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Perhaps you are reffering to the black phenolic spacer between the carb and manifold. It's a heat shield, and is restrictive, but it's the least of your bottleneck concerns, unless you are running:
A racing Beat header and free flowing exhaust or equivalent,
A larger cfm carburetor,
And anything BUT the stock air filter housing.
Then there's the intake manifold shutter valve....
The very slight restriction the plate offers is nill compared to these things, and even if you've remedied all of these other bottlenecks, you probably would hardly notice a ported plate.
Old Nov 17, 2003 | 09:37 PM
Rx7carl's Avatar
Airflow is my life
Its also designed to kill the reversion wave. Thats why its shaped that way. But opening it up to the carb baseplate wont hurt much. But like Sterling said, its not the most restrictive part of the intake system.
Old Nov 18, 2003 | 04:41 AM
ok, thanks for that info, wont mess with it
Old Nov 18, 2003 | 06:08 AM
Rx7carl's Avatar
Airflow is my life
I'm not saying not to. Just that its not the first step in improving the airflow.
Old Nov 18, 2003 | 09:29 AM
slashdawg00110's Avatar
RTFFAQ
I thought the spacer played some role in keeping the carb from getting too hot?
Old Nov 18, 2003 | 09:34 AM
813KR$'s Avatar
TEAM MAZDA
"Perhaps you are reffering to the black phenolic spacer between the carb and manifold. It's a heat shield, and is restrictive"
Old Nov 18, 2003 | 09:40 AM
Rx7carl's Avatar
Airflow is my life
Yes it is for that also.
Old Nov 18, 2003 | 10:13 AM
RTFFAQ
thanks 813kr$. I gotta read *all* of Sterling's posts and quit skimming for the sarcastic, funny parts.
Old Nov 18, 2003 | 10:21 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
It is a challenge I know. Check out Rx7Carl's tutorial on his insulated Cold Air Intake at ftp://ftp2.totalimmage.com/ti/Tutorial_2_CAI.pdf I'm planning on tackling that job this spring before autoX season starts.
scissorhands
Oct 8, 2015 01:17 PM
