sr motorsports and ther turbo staged upgrades
Old Nov 15, 2003 | 04:47 AM
tohype4u2's Avatar
who has had experience with them are they for real I ve heard some people say they are some say they arent are their numbers correct on thier stage II kit 540 rwhp they say at 19psi butt hey want 4700 dollars they are crazy on their stage 5 they claim 690 rwhp on an aggresive bridge port is this fore real isnt cheaper to buy everything seperate and build your own kit so one was selling their stage to kit used for 1899 if there number are true that aint bad but I dont think threse number are right and im sure they were in race fuel what does anyone know
Old Nov 15, 2003 | 08:34 AM
allrotor93's Avatar
cant read run on sentence i have this turbo and i like it
Old Nov 15, 2003 | 07:08 PM
RageRace's Avatar
I would check with Davinci Motorsports about that kit, youll save alot of money . Plus i just think that it is totally unethical that they charge so much money for what they say is a KKK turbo, when in actuality they use a Holeset turbo you could pickup for a few hundred bucks. No saying the Holeset is bad, as ErnieT has made great power with it and ran impressive times, but lying about what turbo comes with the kit, is flat out rediculous and bullshit business.
Old Nov 15, 2003 | 08:53 PM
andericus mack's Avatar
ItotallyagreeIthinkitisbullshitwhattheydoIbought
stage1kitandonlyran12sbeforethe'kkk'diedand
allRaysaidwas'$800fortherebuildsoknowIamgetting
aprecisionturboandhopeforlow11s.
How was that for difficult reading? HeeHee
Old Nov 15, 2003 | 10:01 PM
eViLRotor's Avatar
Brother of the Rotary
I have the Stage 1 for my FC. For a turbo its size (very big) is spools damm fast and makes a lot of power.
Anything past the Stage 2 isn't meant for the street. Not sure I would even put the Stage 2 into an FC...
Old Nov 16, 2003 | 03:51 AM
88fc3sw/HX83's Avatar
I had the stageII in my FC, I made FULL boost by 4500 rpm!
Old Nov 16, 2003 | 09:43 AM
allrotor93's Avatar
i have 15lbs by 3300 with the stage 2.
Old Nov 16, 2003 | 05:08 PM
eViLRotor's Avatar
Damm that is not bad. How much power did you manage to get out of it.
But since I track the car, I need quicker spool than that.
Old Nov 17, 2003 | 12:45 AM
You got to remember that this was on a S4 motor and I wasn't able to do a "complete" dyno run, we stopped at 5500 rpm due to boost creep Anyways, what track will you be runnning on that would require you to need full boost below 4000 rpm?
Old Nov 17, 2003 | 08:13 AM
eViLRotor's Avatar
I just figured the Stage I would spool quicker out of the corners since its slightly smaller and more responsive. I think its more of a preferance than a "need", I guess
Old Nov 17, 2003 | 09:01 AM
Cheers!'s Avatar
Former Rx7 *****
get the stage 6! that is bad ***
Old Nov 17, 2003 | 09:58 AM
eViLRotor's Avatar
Yeah, I've ordered one for my FB...
Old Nov 17, 2003 | 01:39 PM
Brian7's Avatar
So SR is full of **** huh?
Is anyone else on the board running their stage 2 kit?
Old Nov 17, 2003 | 01:43 PM
Icemastr's Avatar
All Motor
The turbos is actually a diesel truck turbo used on the Cummines inline 6 or something like that, you can buy it for $400-$600, pickup a wastegate, have a manifold made (or just use an HKS manifold with spacer) and pick up the oil lines and everything you can make the whole kit for under $2,000 easily.
Old Nov 17, 2003 | 05:10 PM
eViLRotor's Avatar
I would not say they are full of ****. ErnieT made great numbers with his Stage II FD, and the turbo spooled quick.
A bit overpriced for a Holset, for sure.
Not that there is a problem running big diesel turbos on RX-7's!!!
Old Nov 17, 2003 | 05:49 PM
IAN's Avatar
IAN
Rotary Reborn!
You NEED a boost controller.
As in say goodbye to your variable spring control!!!
Old Nov 17, 2003 | 08:25 PM
Brian7's Avatar
What type of porting does he have, and what kind of number's did he put down?
Old Nov 17, 2003 | 09:55 PM
eViLRotor's Avatar
I can't remember off the top of my head...you'd have to look for it.
But he was running 10's....
Old Nov 17, 2003 | 10:16 PM
allrotor93's Avatar
508rwhp at 19psi and a stock port reman.
Old Nov 17, 2003 | 10:45 PM
Carl Byck's Avatar
Mad Man
Allrotor, I remember your turbo failed after a couple thousand miles if I'm not mistaken, am I thinking of a different stage 2 customer? Jim, did you abandon yours as well? What wastegate were you using Jim?
I've spoken with Ray several times, he was short with me, and was not interested in spending any time on the technical aspects of his kits, basicly, it was "do you want to buy one, or not" NOT>>>>>>>>>>>>>>>>>>>>>> Carl
Old Nov 18, 2003 | 08:35 AM
allrotor93's Avatar
i bought mine needing a rebuild. they charged me $890 for the rebuild and it is not ball bearing. i am using the big hks racing.
Old Nov 18, 2003 | 02:12 PM
eViLRotor's Avatar
I keep hearing all these stories of people needing rebuilds after relatively few miles. I guess the turbo being oil-cooled-only is part of the problem.
But with the $$$ Ray charges for a rebuild, I'll probably just get a T62-1 or similar when mine goes
Old Nov 18, 2003 | 02:16 PM
allrotor93's Avatar
good choice. the turbo is bad *** but not when you have to rebuild it at a cost of a new t6x turbo.
cristoDathird
28
May 30, 2019 08:47 PM
