Sponsored by: CARiD
Porting
Old Nov 14, 2003 | 02:22 PM
KKM's Avatar
KKM
Porting
I have searched the forum but I couldn't find a thread which in a simpel yet comprehensive and complete way explains the basics of porting, e.g. what is "street porting", "bridge porting" etc.
I am sure this has been discussed many times, thus could anyone direct me to some informative threads dealing wiht this topic.
BR, Bo
Old Nov 14, 2003 | 06:51 PM
Project84's Avatar
Open up! Search Warrant!
http://www.mazdatrix.com/s.htm
This page has pictures and an explaination of some of the different types of portings.
Old Nov 15, 2003 | 01:07 AM
more on porting
firstly great to be registered on a new rotary club site..thank-you, to all... have a look in the porting section of badrotor.co.nz, but i will contribute plenty of tech info , as i brouse through the site.. thanks
i see corner seals as no hinderance...
Old Nov 15, 2003 | 02:25 PM
bill Shurvinton's Avatar
New? 7 years old is hardly new
Old Nov 19, 2003 | 10:30 PM
black_sunshine's Avatar
Some would describe porting as an art. Basically, the goal of it is to create a positive "swirl" of intake charge within the combustion chambers, to allow air to more easily (and thus decreasing necessary boost, even for a non-turbo), and to tune your HP ( or torque) peak.
This is a thread that I found to be particularly informative and strangely innovative https://www.rx7club.com/showthread.p...hreadid=212537
Maybe this will better help on your porting endeavor(s). Point of advice: Get REALLY good with a grinder before you go cutting on your good housings, or else the grinder will jump out of the port and walk all over the surface of the housing. Also, lumpy ports = lazy ports. I polish mine to a 320-grit finish. On the 6-port motors, when I got all crazy, I used a wire-feed MIG welder to make an "air ramp" on the 5/6 ports (and it worked very well I might add, save NO bottom end power, but who cares; they're MY RACE ports!); sort of an integrated "pineapple sleeve" if you will. Oh, and if you decide to weld in some air ramps, use welder's tape (aluminum tape) to protect the ENTIRE housing, or else it'll have splatter all over it. Use low heat (amperage) too, because if you don't, it'll just disentigrate the housing.
I've given away enough secrets for today....
Matt
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
