Supra SSR GT3's fit on FD?
Old Nov 13, 2003 | 11:18 PM
wReX's Avatar
Does not drive a WRX!!!
I have a freind down in San Antonio who wants some new rims and offered me his GT3's for cheap($1200) off his TT '95 Supra. I searched and only found info about putting stock Supra rims on the FD. The bolt pattern will work, but I also read that the FD Rx7's centerbore is larger than the MKIV Supra's wheel centerbore. Does anyone know if this will be a problem on the SSR GT3's? Will the centerbore's need to be drilled out a little for it to fit correctly? Thanks in advance for any help.
Old Nov 13, 2003 | 11:59 PM
Carl Byck's Avatar
Mad Man
The wheels are almost certainly not hubcentric, so they should fit. SSR makes various spacers for the center bore, you may need to order different ones. IME the wheels are interchangable, I have A 97 Supra, and an 88 FC, I can interchange the wheels any way that I like without a problem, I run FD rims on my Supra with ET Drags(cheap 16" wheels that clear Supra calipers), and I have Supra fronts mounted on my FC(just to roll around the garage, although I have driven to a shop and back). Carl
Old Nov 15, 2003 | 07:53 PM
SleepR1's Avatar
Find the right centering rings, and the Supra GT3 wheels might work on your FD Rx7...
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
