Half Headlight Conversion...
Old Nov 13, 2003 | 05:35 PM
WannaSeeMyWankel's Avatar
STK/A-MKT TII PARTS 4SALE
Question Half Headlight Conversion...
How do you guys wire your headlights to only come up a little bit, or halfway, or all the way down shining through the flash-to-pass lenses?? I think it's so mean lookin and i wanna do it
Old Nov 13, 2003 | 06:03 PM
3RotorRocket's Avatar
Im intrested in knowing also.
Old Nov 13, 2003 | 06:11 PM
genII Drifter's Avatar
first, we need to do a search... then, act upon the information that you found in the search..... then see of it worked.
Old Nov 13, 2003 | 06:26 PM
BigRTII's Avatar
the way i did it is to take out the fuse in the motor bay located above the battery. take out the headlight retractor fuse. Now get under your car and manually turn the manual retractor **** and turn until headlight rises. make sure you count the turns casue it makes them even in the end. the other way to do it is buy a module that does it by controlls inside the car it is about 80 dollars. check my profile it ha a pic of "lazy eyes" not the best pic (camera phone) but you get the idea.
BigRTII's Avatar
BigRTII's Avatar
BigRTII's Avatar
Old Nov 13, 2003 | 06:50 PM
StealthGXL's Avatar
Double post X 2. Heh. I like that lazy-eye look
Old Nov 13, 2003 | 07:01 PM
GEINN FC3S's Avatar
aka sleepy eyez/lazy eyez
Old Nov 13, 2003 | 07:29 PM
BigRTII's Avatar
sorry for postn so much i double clicked in it and it went 3 times ova crazy stuff
Old Nov 13, 2003 | 07:36 PM
Bauer778's Avatar
the way that i did it was take out the head light retractor fuse then go in the car and turn the headlights on, then got to the fuse box and put the fuse in a little bit for a brief second then pull it out at the desired height, thats the easiest way to do it in my opinion
Old Nov 13, 2003 | 08:02 PM
krazykoncepts's Avatar
y did u have to put the fuse back in for a brief second?
Old Nov 13, 2003 | 08:18 PM
StealthGXL's Avatar
For ^^^
So the headlights pop up. That's only for a second you have it in. Then when it gets to the height you want it at you take it out again. Like Bauer said
Old Nov 13, 2003 | 09:27 PM
after reading it again it makes sense..lol
Old Nov 13, 2003 | 09:31 PM
Bauer778's Avatar
yea sorry didnt mention the part about leaving it out thanks Stealth
Old Nov 13, 2003 | 09:33 PM
Turbo23's Avatar
Panda Bear
ask 1FastT2, he has his own personal headlight conversion which is sweet!
Old Nov 13, 2003 | 09:46 PM
cloead's Avatar
sold--no longer in debt
someone was gonna make a mod that would allow you to have a "sleepy" position, along with all the way up and closed.. i dont know if he ever released it
Old Nov 13, 2003 | 09:48 PM
AngelSlide's Avatar
check raretrick.com i know they had one for the 240 maybe they have somethign available for the fc and fd. I know there are kits out there. ones that come with smaller lift arms so the light do go all the way up when on.
Old Nov 14, 2003 | 09:55 AM
SureShot's Avatar
Seduced by the DARK SIDE
A better spin:
That mod would probably be more popular if we called it mean eyez, instead of sleepy eyez.
Old Nov 14, 2003 | 10:03 AM
ViperKillerWannabe's Avatar
Resident Moonwalker
I don't like the look, personally. I'd rather have a sleek light kit like the RE front.
Old Nov 14, 2003 | 10:11 AM
jreynish's Avatar
New Project on the Way...
I think they are quite nice stock! But if you want the sleepy eyez look there is a kit from knight sports! which 1fastT2 has made a very nice setup which is similar!
Old Nov 14, 2003 | 05:45 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Half Headlight Conversion...
If you like the "yet-another-broken-Mazda" look that's fine, but please don't drive around like this at night. That would be dangerous and stupid, as it dramatically reduces the light output of the headlights.
Old Nov 14, 2003 | 06:46 PM
cloead's Avatar
yea dont do it at night.. its pretty bad trying to drive with your lights half open
Old Nov 14, 2003 | 08:34 PM
enrique's Avatar
I bought the pivot controller. it allows the head lamps to be fully opened when turned on and when off you can adjust the amount the head lamp is left open. to some not worth the money. its what I wanted with little effort to get the look and full operation of lights. simple install to. took less than 15 minutes.
Old Nov 14, 2003 | 08:43 PM
aigoonamja's Avatar
I got pivot controller. What color wire do i splice into?
