87 base engine into 88 gxl body
Old Nov 13, 2003 | 10:03 AM
chimp's Avatar
Question 87 base engine into 88 gxl body
Ok, I have an 87 base w/ 5spd. I'm looking at buying an 88 gxl body w/ everything except the engine. I want to swap my current engine into it but the only concern I have is about power steering. My current RX was not equipped with the option so therefore the engine was not outfitted w/ the pump. If the power steering rack in the GXL I'm purchasing remains in the car then I don't know if I will have a problem with the swap. Any insight into this matter would be greatly appreciated. Thanks in advance.
-Chimp
Old Nov 13, 2003 | 10:12 AM
JGard18's Avatar
you won't be bad off to just continue without power steering.
Old Nov 13, 2003 | 12:45 PM
DAN CARWIN's Avatar
all your going to have to do is swap the manual rack from your base model rex and put into GXL. I think manual steering is better any way.
Old Nov 13, 2003 | 02:01 PM
Bukwild's Avatar
if you are going to do a swap buy a t2 driveline and go boosted. Don't do a NA to NA swap. Not worth the time
Old Nov 13, 2003 | 03:17 PM
Aaron Cake's Avatar
Engine, Not Motor
I say swap the manual rack from your car (along with tie rod ends) into the new car. Unless you're a serious wuss power steering isn't necessary. Manual rack is much nicer IMHO, and less to go wrong.
Old Nov 14, 2003 | 04:04 AM
Kai's Avatar
Kai
Rotorphile.
My only suggestion, make sure you get the injectors right. The high impedance to low impedance switch happened in mid '87.
cristoDathird
28
May 30, 2019 08:47 PM
