European Forum European users, post event and club info here.
2000 model year RX7
Old Nov 13, 2003 | 03:49 AM
gtrnick's Avatar
Newbie
2000 model year RX7
Guys,
I am new to this forum and just saw a 2000 RX7 for sale with 16000 miles and a daddy DTM spoiler. Can I know what's the difference between the 99+ RX7s compared to the earlier models and has there been any improvement in stock reliability? Thanks
Nick
Old Nov 13, 2003 | 05:23 AM
Aico's Avatar
Newer=better?
It has improved cooling etc.
More power too if I recall right.
Old Nov 13, 2003 | 05:35 AM
multirotor's Avatar
Rotary Power !
I happen to have read an article about this yesterday. It said: Mazda had the 280hp as target for the last revision of the Rx-7 (280hp is an unwritten max agreed among Japanese car constructors). They managed to reach the target by means of a new turbocharger and new engine management system (32bit). They kept the same short engine and focussed on reliability by improving cooling. IIRC, the 1998 and up Rx-7 breathes 70% better than the older FD3S.
Old Nov 13, 2003 | 05:59 AM
The Ace's Avatar
Greek Power
Exactly!
280HP instead of 250HP (in Japan only, remember ?), different intake tubing, IC tubing and I/C, I *think* bigger/better radiator, slightly imporoved brakes, better ECU (far better), and various aesthetic changes in interior and exterior.
Still think that the SpiritR is BY FAR the vest FD even created
Old Nov 13, 2003 | 06:43 AM
damaged-g00ds's Avatar
Ace if i bought a 93 fd could i fit all these nice things onto it ?
Old Nov 13, 2003 | 08:30 AM
The Ace's Avatar
Greek Power
As always, with enough cash ANYTHING is possible
Finding these items though, that will be difficult. Unless you can get a whole FD from Japan, in which case you might as well import the whole thing anyway
Old Nov 13, 2003 | 09:19 AM
importing parts will be cheaper than buy a newish 99 fd ? wouldn't it hehe an besides all that money for a stock fd... hmm i rather spend it on modifying better than stock but that 32bit computer sounds nice hehe
Old Nov 13, 2003 | 09:24 AM
racer1's Avatar
flying apex seal
Also 99spec has enlarged turbos and the boost pattern is 12-10-12 instead of 10-8-10. Thats the difference on poer i believe.The JDM also i read somewhere they do not have a pre-cat,they have an upgraded Y-pipe.
Old Nov 13, 2003 | 09:27 AM
RX-viper's Avatar
Just check if its actually a 2000 model and not imported in 2000. Check the VIN number!
Old Nov 19, 2003 | 03:08 PM
ANY PICS? DON't MAKE ME ANXIOUS I AM GONNA SMOKE MYSELF TO DEATH HERE
LOL
Old Nov 20, 2003 | 02:54 AM
cruiser's Avatar
New front bumper & lip. Not bigger, but better turbos. Efini y-pipe. Better engine internal cooling. No precat.
Yes, you can convert any FD to SpiritR like. It just costs money.
Old Nov 20, 2003 | 03:21 AM
but in the end it would be cheaper to get a "real" 2000 model than to upgrade all the parts or what ?
Old Nov 20, 2003 | 03:47 AM
but then again, who is gonna leave it stock so like why not just add the good bits and the modded bits and then in the end it would cost the same ?
Old Sep 13, 2005 | 07:01 PM
rousu's Avatar
Red face Fit it right in?
If one did get an imported turbocharger off a 98,
would it fit "plug-to-plug" into a 93,
or would some modifications be needed for fit, function, and control?
Old Sep 17, 2005 | 06:01 PM
FC3S.USD's Avatar
Where is my Life ?
Yes its a direct swap ( its even the same turbos ), The upgraded 99+ versions are direct plug and play also. ( but are a bit different ).
Old Sep 24, 2005 | 03:35 AM
BNA_ELLIS's Avatar
The difference between 99 onwards spec and the older ones are the following.
the exhaust system had 10% less back pressure mainly because of the back box.
the turbos are smaller for better response not bigger, also the turbos have better seals. Boost is up on the ecu to 12 psi and intake breathing improved by a larger opening in front end, water temp are supposedly slightly better with different fans on the radiator. As far as performance is concerned these we're the main changes.
rgds
Kyo
Apr 13, 2019 09:24 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
