I cant get this thing to idle
Old Nov 11, 2003 | 07:32 PM
CptnGnzoEsq's Avatar
Newbie
Angry I cant get this thing to idle
I just bought a '90 Convertable and I got it from my sister-in-law for almost nothing and I figured I could figure it out... Anyways, I just got I back together I can get it to fire up and run but it will not idle. Ihave tried everything I can thing of. So please somebody throw me a bone.
Thanks in Advance
Old Nov 11, 2003 | 07:34 PM
Templeswain's Avatar
Check the TPS and BAC. I'd say start there.
You said "everything I can think of" and I don't know what that is exactly so I'll start with those things above first.
Old Nov 11, 2003 | 07:44 PM
Newbie
I 've checked the timing, my placment on all the vacuum lines, all the coils, plugs, fuel pump and filter, fuel injectors, and several sensors and all seem to be working properly.
Old Nov 11, 2003 | 07:47 PM
Zero Cylinder's Avatar
Strike 3 - Banned
Compression Test.
Old Nov 11, 2003 | 08:48 PM
apreludem's Avatar
this sounds dumb, but make sure your intake is on ( i forgot to put it back on once and would start but not idle :-p) if that doesnt work, then make sure you dont have a vac leak.
Old Nov 12, 2003 | 12:02 AM
trainwreck517's Avatar
Rx-hippie
Check tps, air flow meter, fast idle cam, idle screw, and vac leaks.
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
rxmiles
Aug 24, 2015 02:07 PM
ncds_fc
Aug 15, 2015 10:06 AM
