Engine check light = Bad AFM?
Old Nov 10, 2003 | 02:30 PM
incendui's Avatar
I was flogging my car in 5th last night (cold night too) when the check engine light came on. I immediatly let off and it went off. I was probably getting boost creep at the time, but I have no fcd, so it couldn't have been too much.
When I pulled the codes from ecu today, I got 8, 23, and 42 (not to mention all the others that are caused by no emissions equipment.) I couldn't find 23 or 42 on this list http://www.johnr.com/cpucodes.html but 8 is listed as a bad afm. Why would the light only come on when theres a heavy load on the engine?
Old Nov 10, 2003 | 03:08 PM
Rotary Racer's Avatar
Zoom Zoom Boooom
As far as I am aware there is no code 23 (if some one has had this code and knows what it is please correct me). But code 42 is Duty Solenoid (boost pressure control solenoid).
- Dana
Old Nov 10, 2003 | 03:18 PM
SureShot's Avatar
Seduced by the DARK SIDE
From the FSM:
Old Nov 10, 2003 | 03:51 PM
incendui's Avatar
I'll check again, I may've miscounted. 42 makes sense since I"ve disconected the boost pressure solenoid.
I'm fairly certain the problem I saw was from code 8 though, any thoughts on why this would happen under heavy load only?
Old Nov 11, 2003 | 08:56 AM
incendui's Avatar
befarrer
Microtech
Aug 22, 2015 05:52 PM
gtcd
30
Aug 19, 2015 02:44 AM
cam_7779
Aug 18, 2015 07:48 AM
