Master cyclinder
Old Nov 10, 2003 | 09:31 AM
Jmunk's Avatar
Master cyclinder
I need a new master cyclinder, when i put fluid in it leaks out between the reservoir and the MC . Should i get new bushings or oil rings that the reservoir sits in or a new MC ? Also how do you tell what suspension you have? When i called to get a MC they asked if i had heavy duty or normal suspension ? How do i tell ?
Old Nov 10, 2003 | 10:54 AM
Icemark's Avatar
With suspension they mean do you have 4 piston front brakes or single piston front brakes. 4 piston brakes are in the dealer books as the heavy duty suspension, while the single piston brakes are considered normal suspension.
If you don't know, then you will need to post year and model.
Old Nov 10, 2003 | 06:01 PM
Jmunk's Avatar
I have a 88 N/A pretty sure it's a GTU also. I believe it's a GTU due to it having 15" wheels and no rear wiper.
Old Nov 10, 2003 | 06:43 PM
Icemark's Avatar
88 GTU will have 15" 5 lug wheels, 4 piston front brakes, heavy duty suspension, aero style power mirrors, rear spoiler, under body aero kit and a LSD.
No power windows, now power locks, no rear wiper.
The GXL will have power windows and a rear wiper
The SE will have 4 lug wheels
Old Nov 10, 2003 | 07:21 PM
Jmunk's Avatar
Yup mine has all that. What is the under body aero kit ? Mine has all that you listed for a GTU and a sunroof. So i need the MC for the heavy duty suspension setup ?
Old Nov 10, 2003 | 07:25 PM
Icemark's Avatar
yes, HD suspension.
The lower body aero kit first appeared on the 86-87 Sport, with a lower spoiler skirt in front of each wheel, and a aluminum panel between the engine and rear of the front subframe. A rear spoiler was also included with the aero kit. It lowered the drag of the FC from a Cd of .32 (GXL) to a .289 (the lowest of any RX-7 ever).
The aero kit also came on the 88 TurboII and the 88 GTU with the revised GTU style wing rear spoiler.
Old Nov 10, 2003 | 07:30 PM
derek1987's Avatar
RX7 FOR LIFE! **D
sorry about steal your post but I am have the same problem I have no pedal press and fluid is leaking between the master cyclinder and the brake booster. And now the car seem to stall and smoke a little at start-up.
edit:
1987 Gxl
Old Nov 10, 2003 | 09:28 PM
Jmunk's Avatar
Sounds like you too need a new Master Cyclinder.
Evan Kurtz
Sep 13, 2015 08:40 PM
