fuel cell mounting
Old Nov 9, 2003 | 01:13 PM
Barwick's Avatar
SCCA Rookie
fuel cell mounting
oookay.. any tips on mounting the fuel cell? I've heard a lot of people treat it similar to a stock gas tank and just use thick metal straps (and I'd imagine some padding) all over the place to secure it to the car. That way in a very hard hit, it'll separate from the vehicle and not cause a firey explosion in the back of your vehicle.
My question for you is: Is that preferable? Do you want it to be able to let loose in an extremely hard hit, rather than stay right with the car? Or should I build a hefty metal rollcage type thing to both shield it and keep it with the car?
Finally, can someone show me some pics of their mounting (how they mounted it) or any other people's mountings? I'm mounting an 8-gallon cell in a first gen RX-7, and it's also going to be driven on the street.
Old Nov 9, 2003 | 04:15 PM
Mld>7's Avatar
I Post Mad Quick Yo!
Well the whole point of a fuel cell is so that the explosion does not happen in the first place. A fuel cell will have a sack or bladder inside of it so that even if the tank does take a hard hit and crack, you have to puncture the bladder to make the fuel leak out. Where the tank is situated on the car makes that very hard to do, so your pretty safe with it strapped to you car. Secondly, I cannot say for sure, but I am pretty sure that SCCA does not want fuel cells flying around the track like heat seeking treasure chests of doom. In the case of an accident the track workers have enough to worry about with out a minefield if gas tanks strewn about the track. Make sure its strapped on good.
Old Nov 9, 2003 | 10:47 PM
Barwick's Avatar
SCCA Rookie
I know how they work and what they are. It's not a rotary molded fuel cell (aka the "scarier than stock" type), it's a metal box with the soft bladder inside. 8 gallon.
Old Nov 9, 2003 | 11:34 PM
Silkworm's Avatar
Has been.. hangin' around
I don't have any pics of a mounting, but all the race type mountings I've seen have been boxed in with 1" steel square tubing. I'll see if I can dig up some pics soon.
PaulC
Old Nov 9, 2003 | 11:42 PM
Barwick's Avatar
SCCA Rookie
completely boxed in, or just the top lip is boxed in?
Old Nov 10, 2003 | 09:13 AM
Silkworm's Avatar
They surround the top lip with a 1" collar of steel tubing, then ususally have two or 3 tubes shooting down/under/back up to protect the bottom
PaulC
Old Nov 10, 2003 | 09:56 AM
Barwick's Avatar
SCCA Rookie
ah ok.. kinda like this..
edit: stupid forum won't let it show as just a picture..
Old Nov 11, 2003 | 09:26 PM
tims's Avatar
no it should have support underneath the cell as well as around the lip. like this or this
Old Nov 12, 2003 | 09:12 AM
Barwick's Avatar
SCCA Rookie
ok, that shouldn't be too hard to incorporate
Old Nov 13, 2003 | 08:32 PM
tims's Avatar
no it is a simple fabrication job using 3/4" to 1" square tubing
Old Nov 14, 2003 | 01:24 PM
Travis R's Avatar
trying to build a racecar
Skeese
65
Mar 28, 2017 03:30 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
