Sponsored by: CARiD
Car won't rev!
Old Nov 8, 2003 | 06:52 PM
ImpulseRS's Avatar
Newbie
Car won't rev!
I'm working on a 87 RX7, and for some reason it won't rev, it will start, but just won't rev up! and when you floor it, it just smells like gas! is this a common problem? and any idea what it is?
thanks
Nelson
Old Nov 8, 2003 | 07:03 PM
wwilliam54's Avatar
it WILL run
check your coils
Old Nov 8, 2003 | 07:27 PM
Project84's Avatar
Open up! Search Warrant!
check the timing. I thought I had the marks on my CAS lined up, but when I installed it, the bevel gear that it meshes with caused it to rotate and throw off the timing cause its a straight gear meshing with a bevel gear. I couldn't get my car to rev cause the timing was way off. It would idle and nothing else. I took the cover off the CAS and when I installed it, I could see the insides rotating. Thats how I figured it out.
Kyo
Apr 13, 2019 09:24 AM
morataya
Microtech
Aug 17, 2015 01:04 PM
zuesskroph
Aug 13, 2015 06:05 PM
