exhaust questions
Old Nov 7, 2003 | 05:40 PM
brittol_86's Avatar
exhaust questions
I noticed a big power loss the other day, it gets worse the higher the rpms get. So i suspected it was a cloged cat. I looked at it after a drive, and it was red hot right in front of the cat. I think this means its cloged, but does anybody else have any ideas.
Old Nov 7, 2003 | 06:02 PM
mazdaverx713b's Avatar
Have RX-7, will restore
start the car and go to the rear and put a towel (it may bun your hand) in front of the muffler's tips and have someone rev the car. it should blow the towel around quite a bit. if it doesn't move much or there isn't much coming out of the muffler, your cat is prob clogged. usually red in the exhaust means clogged, esp the cat.
Old Nov 7, 2003 | 08:09 PM
rx78788's Avatar
thanks, the test worked. The towel didnt do anything. now i know it is the exhaust, and that explains why it revs so slow and stuff.
Old Nov 8, 2003 | 02:17 AM
Makenzie71's Avatar
...94% correct.
revving slow and power-loss can be the cat...which in your case it probably is. But every RX7 I've ever owned could get the exhaust glowing without much problem.
Old Nov 9, 2003 | 01:54 PM
rx78788's Avatar
but it revs really slow and the power decrease is unbeilveable
Old Nov 9, 2003 | 03:42 PM
the cat sounds like the problem. if you can get it off, you'll know 100%!!! you may have to cut it off.... but unless you live in an evil emissions state, a header and a good exh. sounds like a good fix...
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
12abridgeport
Aug 17, 2015 06:28 PM
