Help, spring nose in rear shock towers
Old Nov 7, 2003 | 10:07 AM
caoict's Avatar
Bought the car with koni's on it, switch to tokico to soften the ride abit. Was hoping it would also help with the spring noise. It did not.
During normal drive, springs are quiet, but if you hit a bump or are driving through a bumpy parking lot, it squeeks on compression of the spring.
Any help appreciated.
Old Nov 7, 2003 | 10:12 AM
ptrhahn's Avatar
Its probably your sway bar mounts... if they are upgraded, the urathane bushings squeak like a ****. Grease 'em w/ cv-joint grease.
Old Nov 7, 2003 | 10:15 AM
caoict's Avatar
They are upgraded, kinda stiff. The guy I got the car from had it sitting for a while. Thanks
Old Nov 8, 2003 | 06:22 PM
caoict's Avatar
Tried to grease bushing, but no help. sounds seems to be higher in the shock tower.
Old Nov 13, 2003 | 04:39 PM
caoict's Avatar
Squeek is either a lower speeds or big bumps on higher speed.
Old Dec 3, 2003 | 02:26 PM
caoict's Avatar
Bump.
I replaced my rear shocks with tokico adjustable. Should I have replaced springs or anything else?
matty
Jan 18, 2020 10:39 AM
