What Coils to use???
Old Nov 5, 2003 | 09:47 AM
John64's Avatar
What?
Ok, I'm doing a tune up on my 85 GSL-SE and there are two types of coils a Mitsubishi and a Hanshin listed for replacements. How do I find out which one I have? The coils in the car now say Diamond LB-84 12V 5218.
Thanks Alot
Old Nov 5, 2003 | 10:06 AM
813KR$'s Avatar
TEAM MAZDA
buy after market coils that produce more spark, they dont cost that much more and will smoth out your engine.
Old Nov 5, 2003 | 10:07 AM
813KR$'s Avatar
TEAM MAZDA
I use MSD Blaster 2 coils.
Old Nov 5, 2003 | 01:19 PM
Northern 7's Avatar
Actually, aftermarket coils are usually cheaper - maybe not blasters but, IMO, those are over kill in a stock set up. Accel's are decent and cheap
Old Nov 5, 2003 | 02:43 PM
Jeff20B's Avatar
Lapping = Fapping
Hanshin and Bosch work.
Old Nov 5, 2003 | 02:51 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
I went with Crane Fireball's from Victoria British, and can't say that I noticed any difference at all. Piece of mind is worth the added expense, however.
The original coils seem to work just fine after 20 years, and for tune-up purposes, it seems that money is better spent on a new cap and rotor, new plugs, and a new air filter, rather than replacing coils to get better performance. This is for stock, or slightly- modified, of course.
If it were me, I would spend the extra money on a quality timing light and an oil-change - you'll probably experience better performance by checking your timing now and then, and having clean oil to inject. HTH,
Old Nov 5, 2003 | 07:21 PM
Matty's first 1st Gen's Avatar
Boosted 7
i used 3 accels for my dlidfis setup, and they are garbage, they wern't even sparking my trailing, and the spark for the leading isn't that hot, i was dissapointed, but a good price though
Old Nov 5, 2003 | 07:57 PM
boosted12a's Avatar
I no nothing
just use second gen coils. get the whole igniter and coil for leading. instant direct fire! and use a leading igniter and trailing coil for the trailing. cheap and easy, good power gains too
Forseti's Avatar
on a sidenote I bought accel's plug wires and one of them went after maybe 2 months. Between that and other feedback I'm not so sure about Accel.
Old Nov 6, 2003 | 01:08 AM
exodus82's Avatar
When i switched from stock to Accel wires and coils, it was like a whole new car. It starts alot better when its cold now.
Old Nov 6, 2003 | 02:42 AM
Jeff20B's Avatar
Lapping = Fapping
What's in your car?
Old Nov 6, 2003 | 06:06 AM
John64's Avatar
What?
Thanks for all the replies, but my question did not get answered. What is the difference between the Mitsubishi and Hanshin coils?
Old Nov 6, 2003 | 09:46 AM
boosted12a's Avatar
I no nothing
msd/ second gen coil leading, secondgen trailing coil on the trailing. the secondgen igniter is in work
Old Nov 6, 2003 | 10:56 AM
813KR$'s Avatar
TEAM MAZDA
Sounds like to me the mits and hanshin are stock replacements, dont know. I do know the mitsubishi is the stock coil. I also know, is I have used MSD Blaster2 coils and have experienced noticable gains.
Old Nov 6, 2003 | 12:16 PM
Northern 7's Avatar
You're also running a direct fire set up with an MSD - in this case, blasters makes sense. For stock replacements (firing up those stock ignitors), way too much money and the gains would be most likely unnoticeable.
sounds like a few bad experineces with Accel (and a few good ones) - I have run Accel for 5 years on 2 different FB's and they work great. Both cars were set up with MSD's
Old Nov 6, 2003 | 01:56 PM
Jeff20B's Avatar
Lapping = Fapping
I'd say the Mitsubishi coil is like the Hanshin as well. Just look for any wording on the coil which should tell you if it is supposed to be hooked to a transistor ignition, or a ballast resistor/points ignition. Hanshin and Bosch both say this, as do Diamond.
Old Mar 30, 2004 | 12:31 AM
Jon017's Avatar
I had accel coils in my car and toasted one. Then i went and read and they arent rated for that high of reving, i think it is like 6000 or 7000 rpm but i cant remember exactly. Also i have toasted one of the accel spark plug wires it was grounding itself on the bar going across. I went and put in msd blasters and there great
Old Mar 30, 2004 | 10:02 AM
YapaKanichi's Avatar
Smile Like a Donut
I have accels on my car and my spark is fine.
RuffRx7
Oct 1, 2015 03:08 AM
GKW
Sep 28, 2015 04:34 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
