ok, i'm a f'ing idiot when it comes to stereo stuff..
Old Nov 4, 2003 | 10:17 AM
Sir Rupert Hobo's Avatar
seven-less
so i did a search and it says that my 88 GXl (with dash speakers) would work better with midrange speakers in the back... what is the MAXIMUM size i can fit in the rears without having to cut anything?
and what size for the dash? i tried searching, but that just makes me even more confused.
i'm not getting a sub/amp for now. and my car has absolutly NO speakers, but still has the stock head.
so could i get 4"(or bigger) mids in the front and 5 1/2" mids for the rears?
thanks
Old Nov 4, 2003 | 11:34 AM
I have an 86 GXL and I have 4's in the front and 6 1/2's in the back. As far as I have been told, you can fit 8's in the strut towers without a mounting plate, but I just went with the 6 1/2's.....they sound great. Go to www.crutchfield.com and check out the speakers that they have there. You can put in what kind of car it is and they will show you what fits. You can get a set of mounting adapter plates for the 6 1/2's to fit them in the rear, but I just modified the stock ones on mine. My next stop is probably gonna be an amp and subs, but not too big--need the FD alternator first!!
Without cutting, stick to 4's in the front. They are a direct fit replacement, but be careful if they have a high tweeter--it might stick out too far to fit behind the factory grilles.
Old Nov 4, 2003 | 12:52 PM
seven-less
thanks for the reply.. i was looking at the rears yesterday and thought "this has to be bigger than 4 inches".
Old Nov 6, 2003 | 10:14 AM
yeah man you can fit up to 8's in the rear but there is no need if you are going to put subs in later so 61/2's in the rear shopuld be fine thats wut i have in my 87 gxl
Old Nov 6, 2003 | 10:22 AM
seven-less
grey fc... do you know whati should do with the front speakers? they don't work.. should i bypass the stock amp?
Old Nov 7, 2003 | 07:33 PM
seven-less
anyone? should i bypass the stock amp?
LongDuck
Oct 7, 2015 08:12 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
