Anyone know where to get aftermarket lower links for 1st Gen?
Hello...new member here! I am looking for the aluminum links for the rear end that have a heim joint at each end. My father has them on his race car and I don't know who made them. Any ideas?
Possibly SDJ Motorsports, G-Force, or maybe Mazda Trix or Tri Point for pre-mades.
Also to do it on the cheap, why not have them made. Chassis Engineering, IIRC, located in Daytona, FL. They mainly do drag stuff but sell all of the tubing for cages, supports, all different sizes, types, (DOM, drawn over mandrel smooth wall, Chromoly, etc.). They will make whatever you need, weld it all up, everything, the are very accomodating. For the links, you will need thick wall tubing, probably 1" or 1 1/2" OD, shank adapters that weld in, and two spherical bearings. measure the length give them a call, and they will take care of you.
I got them to make me a panhard bar. to have it arrive at my door ready to drop on the car, after adjusting the length of the rod ends of course, was only ~$50.00.
Travis
Travis
Mazda Motorsports has these:
Part No. 0000-04-7423
TRAILING ARM KIT, LOWER
Notes: Includes two (2) new modified lower trailing links. Rubber bushings are replaced with spherical bearings. helping to eliminate 'binding' problem in rear end. Available by special order only. Spherical bearing also available separately (0000-04-7422).
Price: $377.85
Part No. 0000-04-7426
Description: WATTS LINK KIT
Notes: djustable. Includes two heim jointed links with spherical bearing ends.
Price: $183.75
Part No. 4352-28-400
Description: WATT LINK - REAR 1 RX-7 12A, 13B 1979-85
Notes: Identical to stock, except with spherical rod ends for adjustability
Price: $57.50
Price: $377.85
Price: $183.75
Price: $57.50
The watts link parts could be made with high quality Aurora spherical bearings for probably 50-75 bucks. Though, I am a strong proponnent of panhard. helps eliminate binding and also allows you to adjust the rear roll center, where using the stock watts link, you are stuck at the current roll center, which is too high as it is. Also, to really help eliminate rear end binding, need to get rid of the upper links and put a torque arm in. This is a lot noisier, but a lot more precise. plus if you are looking at rod end lower links, probably not worried about streetability, to a point, as much anyway.
Travis
Travis
Wow, thanks for all the info guys! I just got back from Lime Rock last night...what a great day! Ran an 18 lap sprint race and a 1 hour enduro. I am tired today! The car ran perfectly. My father wrecked the front of his 83 RX-7 race car, so I borrowed his panhard bar and lower links. What an amazing difference in the handling! I was told by a fellow RX-7 racer that a company called "Coleman" something or other can make the links. Anyone heard of them? I have done a search online but couldn't come up with anything.
Travis - I will DEFINITELY call the Chassis Engineering company. If they can duplicate the panhard bar from my father's car for around $50.00, I'll put their name all over my race car!
ISC Racing sells used lower links with the aforementioned Mazdaspeed Spherical Bearings already tack welded in place. ready to go bolt in.
http://iscracing.net/
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
0000047426, 13b, adjustable, dyno, heim, jointed, link, links, mazda, mazdacomp, motorsport, motorsports, numbers, offer, price, sdj, speedsource, watts
