serious Nikki carb problems along with big timing problem
Old Oct 28, 2003 | 04:35 PM
Hans's Avatar
ok stock 83 with holley blue(3psi)
only thing after manifold is a flowmaster(40srs), hey it was free
carb has no emissions no choke
no vaccum leaks I can find, have gone over so many times
idle screw 3.5 out
start up and the thing idles at damn near 150rpms any gas and it dies imediately. i try changin idle speed and it dies.
if i give it gas 1 outta 7 times maybe i get nice flamage out carb. is it a timing problem?
heres the deal i got out and pop the hood and toss on some jumpers(dead *** battery) so i can move it from my house to a bud's shop where it will stay for a while during a rebuild etc.
Distributor is loose from the retaining bolt(you know its the one you loosen to move dizzy left or right to adv, ret timing)
I pull out my handy dandy wrench and pow about 10ft/lbs and the head snaps off. well i reach down and with the luck of the gods apon me i bump the dizzy outta the hole, so I have no idea where to replace dizzy. I searched my haynes and no go
the Mazda shop manual online, i couldnt find it. so i stuck it in with the arrow on the leading part of the rotor to L1 on the dizzy with the crank at the yellow mark.
i most likely confused the hell out of anyone whom has just read this so I appologize for that, but i cant figure this out and am getting tired of the car real quick. bought to take it to scrap yard, so unless i get it working or someone gives me 500 bones its out like a bad lightbulb
Old Oct 28, 2003 | 06:24 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
You can't expect help with the carb until you know the dizzy's in right. There's a list forever long to troubleshoot. Certainly noone wants to type the books-worth of **** that could be wrong until you search out the timing issue first.
...especially if you're expressing an almost nonconcern for whether the car lives or dies.
I know the dizzy-setting info is here buried somewhere. Address the carb problem afterwords, and for Gawds sake, don't futz w/the carb no more till the timing is right.(ehh, & don't burn yer face off, either! )
Old Oct 28, 2003 | 07:43 PM
Rx7carl's Avatar
Airflow is my life
85 and 80 FSM
http://www.wankel.net/~krwright/cars/rx7/85_manual.html
http://www.wankel.net/~krwright/cars/rx7/80_manual.html
Old Oct 28, 2003 | 07:52 PM
mar3's Avatar
Administrator
For this Forum....
TDC from scratch...
Old Oct 28, 2003 | 08:18 PM
bliffle's Avatar
"so i stuck it in with the arrow on the leading part of the rotor to L1 on the dizzy with the crank at the yellow mark.
Sounds right.
B
Old Oct 28, 2003 | 09:46 PM
Hans's Avatar
Sounds right.
B
well if this is right timing is spot on... reread 1st post with ignition ignored
about the concern of car. I hope if i say i hate it and im going to get rid of it it will start for me. I love it and its not going anywhere, just have to vent
Old Oct 28, 2003 | 09:56 PM
Makenzie71's Avatar
...94% correct.
it's pretty easy to retime the dizzy...or get it close...then put a light on it. My question is how did you bump the dizzy out?
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
