Enkei RPM2
Old Oct 28, 2003 | 02:20 PM
Scrapiron7's Avatar
STi Boxer power!
Enkei RPM2
Trying to get some input on this combo, and whether or not it's even doable. I want to put a set of 17x9.5 Enkei RPM2s on all the way around, and run 275/40/17s on all 4 corners. I was looking at the Yokohama AVS ES100 tires, Z rated. My FD has Tanabe Sustec Super-H Springs which provide around a 1.5" drop.
Any forsee any problems with this setup? Or any fitment issues? Anyone have any input on the RPM2s or the Yokohamas? Thanks.
The full package will run $1484 shipped.
Old Oct 28, 2003 | 02:23 PM
bkapold@aol.com's Avatar
the rear will be fine...whats the offset up front? +35 or 38+ I'll guess....Should be okay....anyone?
Old Oct 28, 2003 | 02:26 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
Can you run a 275 on those? I'm running 8.5/9.5 f/r with 235/45 and 255/40 nitto 555s. With Tein RA's and dropped about 2" I had some rubbing issues. Bad ones. It's ok now. So long as I don't take a bump on a turn. The rears are fine, though I don’t know about that size. Hell, of you can, do it. Maybe I’ll put some bigger meat on there after all….
Old Oct 28, 2003 | 02:29 PM
Scrapiron7's Avatar
STi Boxer power!
They look to have an offset of 40hb according to the site I am pricing them from.
Old Oct 28, 2003 | 02:45 PM
ptrhahn's Avatar
You might have trouble w/ a 9.5" +40 and a 275 tire. Thats a tall, wide tire. Most folks running that size will do it on modular wheels, 10" wide w/ offsets around +50 to +52 (requiring coilovers)...
However, a 275 will fit on any rim from 9-11" generally... so it'll be OK on the back.
Old Oct 28, 2003 | 02:49 PM
Scrapiron7's Avatar
STi Boxer power!
Hmm so I might have to step down to a 255/40/17 on the front eh? Bummer
Old Oct 28, 2003 | 03:14 PM
ptrhahn's Avatar
275/255 combo is what i'm planning on running next time around.
Old Oct 28, 2003 | 03:40 PM
Scrapiron7's Avatar
STi Boxer power!
Pics of RPM2s
Old Oct 28, 2003 | 03:41 PM
Scrapiron7's Avatar
STi Boxer power!
Old Oct 28, 2003 | 04:39 PM
Railgun's Avatar
I won't let go
It'll look good!! I'll post a pic tonight of mine.
Old Oct 29, 2003 | 12:35 PM
namasan's Avatar
i forgot i own an FD
Here's a pic of my setup:
rpm2
yokohama avs es100's
18x8 45 235/40/18
18x9 38 275/35/18
tein flex lowered 342mm (wheel center--fender)
http://members.***.net/namasan/7/rear.jpg
No rubbing on the street, haven't had a chance to test it out on the track yet though.
Old Oct 29, 2003 | 05:02 PM
Mean Machine's Avatar
where do can u buy enkei rims ive never seen them forsale anywhere.
Old Oct 29, 2003 | 05:18 PM
Louis M's Avatar
discounttiredirect.com
Old Oct 29, 2003 | 06:23 PM
namasan!!!i like the way ur rims look can u post more pics of ur car?
Old Oct 30, 2003 | 09:33 AM
Scrapiron7's Avatar
STi Boxer power!
rpm2
18x8 45 235/40/18
18x9 38 275/35/18
That looks SOOO nice
Old Oct 31, 2003 | 12:59 PM
Louis M's Avatar
more pics?
Old Nov 2, 2003 | 05:14 PM
Quiksilver540's Avatar
How do you guys with the larger than 9" width get them custom? Do you have to order directly thought enkei?
Old Nov 4, 2003 | 11:55 AM
Scrapiron7's Avatar
STi Boxer power!
That's really weird. They changed the sizes on the site. I still have the print out I made that shows 9.5 inch rims.
Old Nov 4, 2003 | 01:47 PM
I called up Enkei and they said that larger sizes could be ordered through a distributor (Les Schwab, Rishie) from Japan.
