bumper sticker
Old Oct 27, 2003 | 10:59 AM
Aaron_M's Avatar
bumper sticker
i have a big *** bumper sticker on my car that must have been there for a year and i cant peel it off?How can i get this off??Thanks
Aaron
Old Oct 27, 2003 | 12:35 PM
French RX7's Avatar
Try lighter fluid and a lot of patience. Make sure you test that fluid on an insconpicuous part of the body to make sure it doesn't harm the paint, but it has always worked for me.
Old Oct 27, 2003 | 01:53 PM
bouis's Avatar
Don't use lighter fluid! Wal-Mart sells something called "bug off" or similar which removes adhesives and tar very, very well without any risk to plastics or paint.
[edit]
It also smells like oranges, if that's any help.
Old Oct 27, 2003 | 02:42 PM
Lee Lyons's Avatar
there's a type of remover I don't know if they sell it in the states but it's called goof off and it works great on just about anything. I know it eats plastics but I'm not surea bout paint
Old Oct 27, 2003 | 03:01 PM
Metallic_rock's Avatar
Ride 'n Style
Goo Gone - works great!!! Wal Mart sells it too. It also smells like oranges.
Old Oct 27, 2003 | 04:07 PM
Tripple 7's's Avatar
Autozone sells Bumper sticker remover that will remove it without hurting the paint.
Old Oct 27, 2003 | 04:44 PM
1stgen4life's Avatar
Leaking oil like crazy!
Like Lee Lyons said, goof off works well for everything of that sort. But as french said test anything you are trying on som inconspicuous(sp?) part first. Good Luck
Old Oct 27, 2003 | 04:59 PM
Mills's Avatar
procrastination engineer
Buy a heat gun or use a hair dryer and plastic razor blades w/a handle. That, along w/adhesive remover on a rag is what we use at our car dealership.
Works slickernshit. I just removed all the old adhesive on a set of side skirts this way. You can use a regular razor blade, but only if you have the hands of a surgeon.
Old Oct 27, 2003 | 05:17 PM
pratch's Avatar
Mazspeed.com
goo gone, goof off, etc are petrolium distillates. Great for removing adhesives without doing much (if anything) to paint. Most of them also are scented that lovely orange.
Best bang for the buck.
Old Oct 27, 2003 | 05:24 PM
Lee Lyons's Avatar
Pretty much anything with works even a soap and water liquid might work but check first on something to make sure you don't get any discoloration or peeling of paint before putting it on your car.
Old Oct 27, 2003 | 06:51 PM
TexasGunRunner's Avatar
I heard a pressure steam cleaner would take them off...at least that was the service they offered in '96 to remove certain bumper stickers for a certain president.
Old Oct 27, 2003 | 07:17 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
3M Adheasive Remover.
Old Oct 27, 2003 | 08:05 PM
Keaponlaffen's Avatar
yeah, pressure washer takes bumper stickers off....
Old Oct 28, 2003 | 01:18 AM
Cody's Avatar
SKELETOR!
Crashing into stuff helps....but it has to be the right angle. It might take a few times, and a few Rx7s....but you'll get the hang of it.
Old Oct 28, 2003 | 02:19 PM
French RX7's Avatar
Why can't you use lighter fluid? I've used it often without problems and no damage to paint. I'll have to try that orange stuff next time and compare results.
atticus_jay
Interior / Exterior / Audio
Oct 23, 2015 11:16 AM
