86 Transmission to a 90 vert.
Old Oct 25, 2003 | 06:58 PM
Cool 86 Transmission to a 90 vert.
I had some problem with the transmission on my 90 convertible, it can only shift to 1st and 2nd gear and can't go into the rest. Does anybody know if a 86 rx7 tranny will fit right on the vert?
Old Oct 26, 2003 | 12:34 AM
RX-Heven's Avatar
I'll blow it up real good
If the tranny is from an NA RX7. then yes, there is no problem.
A turbo II tranny would either require a custom driveshaft to mate the na rearend to the TII tranny. Or the rearend (or pinion flange at least) and driveshaft from the TII drivtrain (preferable).
Old Oct 26, 2003 | 09:42 PM
ok then, if they are all NA then they should fit thanks for the help.
MILOS7
Oct 9, 2015 02:19 AM
MidnightOwl
Sep 25, 2015 10:24 PM
