R1 or something else?
Old Oct 20, 2003 | 08:49 PM
Larz's Avatar
Potato Love
I have a 93 touring FD and want to upgrade the suspension. Should I convert it to an R1 or go for something completely different? Is the R1 suspension all that much better?
Old Oct 20, 2003 | 08:58 PM
Raziel's Avatar
Womp Womp
I went with something else. Why go back to stock?
Old Oct 20, 2003 | 09:40 PM
Mahjik's Avatar
Mr. Links
Re: R1 or something else?
Compared to what you can purchase today, no the R1 suspension is not that much better.
What are you planning to do with your car? Drag race? Road Race? Just normal street driving? Depending on your application, suspension suggestions will vary.
Old Oct 20, 2003 | 09:48 PM
skunks's Avatar
I'm a CF and poop smith
Tien HT coilovers
1007lb spring rate, 18/kgf stiff enuf for ya :p
Old Oct 21, 2003 | 12:07 AM
rynberg's Avatar
The only difference between suspensions for 93 was that the R1's had stiffer shocks. Springs, bushings, and roll bars were identical.
For 94-95, the rear bar on non R2 models was smaller and the bushings were softer.
A very good upgrade for you would be Koni shocks. At their softest setting, their valving is very close to the R1 shocks. You can then stiffen them up for track use.
Given the problems I'm having right now with my aftermarket springs, I wouldn't go that route if I had it to do all over again. I would just upgrade the shocks and then go to full aftermarket coil-overs later if you track the car regularly.
Old Oct 21, 2003 | 06:10 PM
Larz's Avatar
Potato Love
I want the car to be for street use. Nothing high and to the right for the track.
