Urgent help on rims
Old Oct 18, 2003 | 03:40 PM
Urgent help on rims
I wat to get volk CE28n's in 17x8 in the front and 17x9.5 in the rear. I need to know if I need to get coilovers first the n run the rims or if I can get the rims now. WHat off set . I heard +38 in the front and +35 in the rear. Now wht is the widest tire. 275x40 in the rear? with no coilovers. just stock? and 225x40 in the front stock suspension? please need your info, anyone
Old Oct 18, 2003 | 08:23 PM
AMRAAM4's Avatar
twinturboteddy ws my idol
this is "urgent"ly needed info??
Old Oct 20, 2003 | 09:19 PM
yes it is urgent
I have the 2000 dollars. nad I know the rims are around that. If I cant get the rims I will gee the coilovers. The TEIH HE or RE with edfc for 1600. So Iwant to get them tis week. any help?
Old Oct 22, 2003 | 07:43 AM
bkapold@aol.com's Avatar
Urgent help on rims
Okay, using either coilovers or not you can use 17 x 8 35mm ....+38mm will work too. I have 17 x 9's w/ +35mm
The 17 x 9.5's I'd get a 35mm OR again a 38mm will work....Mine are +38mm -17 x 9.5's
and those sized tires will fit on this combo...at least in my experience
Old Oct 26, 2003 | 07:17 PM
guys I need more info. i heard if I do get these offsets(+38f &+35r) now, with no coilovers they will fit. But then after when I get coil overs I will have a offset problem? what are th real offsets I can run. Please any info?
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
