Tire and rim question (FM-10)
Old Oct 16, 2003 | 07:32 PM
Mr rx-7 tt's Avatar
rotary sensei
Purchasing some Fikse FM-10's and I am going with 17X10 Rear
17X8 Front
The car has been lowered with eibachs and I am slightly concered with rubbing. I was going with 275/40/17 back and 245/40/17 in the front. My questions are:
1) Fikse recommends 225/50's in the front but I have run 245's and have had no rubbing on the stock rims. Is it ok to keep the 245's ?
2) Will 8.5 in the front rub ?
3) What is the largest I can go up front without rubbing ?
4) Does anyone know what offset I should be running with these tires?
Thanks...
Old Oct 16, 2003 | 07:40 PM
Brentis's Avatar
search a bit. lots of info
Old Oct 16, 2003 | 07:50 PM
SleepR1's Avatar
9 x 17 up front. Offset will be 45 to 50-mm. You can run 255/40-17 with no problems. Actually you can push the width all the way to 9.5 x 17 with 50-mm offset using 255/40-17 tire size up front. Don't mess around with 8 wides with 225/45-17. That's too close to stock for the money you're spending!
Old Oct 16, 2003 | 09:56 PM
rynberg's Avatar
Yeah, if you are buying the rims new, I would get either:
Neutral setup: 17x9, +50 offset for all four wheels, running 255/40 17
Staggered setup: 17x9, +45 to +50 255/40 front, 17x10 +50 275/40 rear
"Volk" setup: 17x8.5/17x9.5 +40 to +50 running 235/45 or 245/40 front and 265/40 rear
Of course, you could always go nuts and install 4 18x10s +50 offset running 285/30s (with coil-overs)....
Lucky guy, please post pics when you get them mounted...
Old Oct 16, 2003 | 11:50 PM
Mr rx-7 tt's Avatar
rotary sensei
Don't you have to roll the fenders to run anything larger than an 8.0? ? I think my buddy has 8.5's and it screwed up the fenders...
Old Oct 17, 2003 | 09:53 AM
Mr rx-7 tt's Avatar
rotary sensei
I am also wondering about the front offset..i see some of you say 45 and some 50 ?
Old Oct 17, 2003 | 10:00 AM
redrotorR1's Avatar
LS6 Convert
You shouldn't need to roll the fenders. It's a good insurance policy to do so, but not necessary. Dial in some negative camber and don't lower the car so dern much. I have seen 18x10's fitted without fender rubbing issues .... just a lot of negative camber and good suspension setup.
Old Oct 17, 2003 | 10:13 AM
ptrhahn's Avatar
The standard Fikse fitment is 17x10 +44 rear, and 17x8.5 +37 front.
Old Oct 18, 2003 | 12:54 PM
saxyman990's Avatar
Place your ad here...
I have FM10s on my car. 17x9 with 255/40/17's on all four corners (I went with a non-stagered setup so that balance would still remain neutral, plus I have the option to rotate tires). I absolutely love the setup and would recommend it to my best friend in a heart-beat.
I do not have rolled fenders, plus the car is dropped about 3/4". I also run open track events quite frequently. I have no problems with rubbing.
As a bonus, the car looks freaking sweet with these things!
Old Oct 19, 2003 | 02:05 PM
7racer's Avatar
saxyman,
what offset do you have for the 17x9
and does anyone know if these will clear the RZ calipers???
Old Oct 20, 2003 | 11:50 AM
saxyman990's Avatar
45mm offset on mine
Pretty sure that they will clear the RZ calipers, but I'm not totally positive of that. Anyone have any personal experience with this?
