How to tell dead LSD
Old Oct 16, 2003 | 05:53 PM
samnt650's Avatar
How can I tell if my LSD need rebuild? This is a 87 T2, so I am guessing I have the plate type LSD which will wear down in times. The car has 125k miles and mainly use on track...
Old Oct 16, 2003 | 06:43 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
it needs a rebuild. No rx7 clutch type diff lasts that long
Old Oct 16, 2003 | 07:02 PM
eoph's Avatar
yeah, just jack up the car and c if one wheel spins or both
Old Oct 16, 2003 | 07:03 PM
samnt650's Avatar
thats the problem. both wheel spin in same direction.
Old Oct 16, 2003 | 09:22 PM
Cheers!'s Avatar
Former Rx7 *****
you can't tell by jacking the car up... you can't generate enough torque on teh wheels to cause the discs to show slipping (IE Wear)
go find a road in the middle of nowhere with a gravel/sand shoulder.
stick 1/2 the car on the sand/gravel and the other 1/2 on teh pavement.
Have a friend watch from outside the car... rev the car in 1st gear and launch it at like 4000+ rpms and have your friend watch.
btw hang onto steering wheel tight!
u should know prettyu qucikly if your rear end if fubar
Thor 18
Sep 28, 2015 07:35 PM
