Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Could someone tell me the process of hooking up an ECU?
Old Oct 13, 2003 | 07:24 PM
Sprockett's Avatar
Former Rotorhead
Hey everyone,
I just bought an M2 Stage III ECU from a fellow board member. This is supposed to arrive Thursday, but I won't be able to get to it until Friday. I need to have it in by Friday night because I am going to the Banzai BBQ on Saturday. Could someone please tell me what I have to do to swap out the stock ECU and put this one in? Is it just unplugging and replugging or is there more to it than that?
Old Oct 13, 2003 | 08:13 PM
rynberg's Avatar
*Pull up scuff plate, it just has two snaps.
*Pop out the two plastic clips for the passenger side kick panel and remove panel.
*Undo a few screws holding the stock ecu and carefully unplug wiring harnesses from the "front" of the ecu.
*reverse instructions for the new ecu
Just be careful with the wiring harnesses and make sure that you don't disconnect the grounds. It's really easy.
Old Oct 13, 2003 | 08:58 PM
Sprockett's Avatar
Former Rotorhead
which of the wires are ground wires?
Old Oct 14, 2003 | 12:28 AM
rynberg's Avatar
I forgot, you won't have to mess with the ground wires for the M2/Pettit ecus (standalone only). Don't worry about it. And I forgot something important -- FIRST STEP: DISCONNECT THE BATTERY!
mulcryant
Sep 9, 2015 05:24 PM
SCinfidel
Sep 8, 2015 05:36 PM
nkuhajda
Sep 7, 2015 04:07 PM
