Do I have to use the Mazda Fuel Filter?
Old Sep 28, 2001 | 06:24 PM
S.W.P.'s Avatar
Do I have to use the mazda fuel filter or can I use a different brand that cost less? Is the mazda filter the best or is there a better one?
Old Sep 28, 2001 | 06:44 PM
Scorpio's Avatar
I did mine recently (hopefully Jim won't read this post) and I went with the one from Rotary Performance because it was so much cheaper. It sure looked the same as the old one...car drove the same too. :)
Hope this info helps...
Old Sep 28, 2001 | 07:09 PM
GsrSol's Avatar
Z06 powered FD
I have always went with stock fuel filters because think of how many people never change them and thier cars are still running. If you buy a cheaper one you take the chance of it possibly failing or not flowing enough. Mazda specificly designed it for this car so thats why I use the stock one. RP does have a stock replacement that is cheaper. www.rx7.com
Old Sep 28, 2001 | 09:58 PM
silver93's Avatar
I use a Wix filter from Napa ($30) with no problems.
perfect fit.
Old Sep 29, 2001 | 05:44 AM
clearthinker's Avatar
stock
Go with the stock filter...its waaaayyy to important piece of equipment to save a few buck on. It's not like you buy one every 6 mos.
Go with mazda...OEM
Old Sep 29, 2001 | 07:36 AM
CantGoStraight's Avatar
What's your point ?
Purolator all the way
I use the Purolator fuel filter and oil filter, they are both cheaper and available at Discount Auto parts...fuel ran $22 and top of the line oil filter was $6.00 Purolator rated as best in comparison test. Will see if I can find the part numbers for you.
Old Sep 29, 2001 | 01:35 PM
rxrx7's Avatar
I use a K&N fuel filter. Flows like 10X's better and is about 1/10 of the size. I think it was like $50
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
