hard gas pedal
Old Oct 10, 2003 | 09:43 AM
chitek's Avatar
hard gas pedal
I was driving my brothers 84 gsl and I noticed the gas pedal was somewhat stiff. It would also go to the right side a bit so I don't know if the problem was that it was hitting the carpet. I check the throttle cable later on that day and traced it to the carb. I tried giving it gas by hand but the throttle mechanism was stiff when turning it too. A hell of alot stiffer than in my Toyota mr2 turbo. Is there a way to adjust this so it is not that stiff? Does it need WD40 or something like that?
Old Oct 10, 2003 | 10:01 AM
Gregs's Avatar
clean all the lingkage on the carb, and replace the throttle cable that should do the trick
Old Oct 10, 2003 | 10:41 AM
pillage6's Avatar
Check the return spring too.
Old Oct 10, 2003 | 11:31 AM
chitek's Avatar
Where is the return spring located?
Old Oct 10, 2003 | 12:53 PM
Rx7carl's Avatar
Airflow is my life
Look here for info
http://www.cardomain.com/member_page...=266801&page=4
Donald Hampton
16
Nov 23, 2022 06:38 PM
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
