Offset gurus! Need advice on some 17 x 8's and 9's...
Old Oct 7, 2003 | 10:54 AM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
Looking at a set of rims for a FC...
17 x 8 up front...my offset choices are +25 and +35...thinking of going with 225/45-17. So...which one +25 or +35?
17 x 9 out back, looks like my only choice is +15...for 255/40-17. Is that going to work?
Thanks in advance!
Kevin
1989 GTUs "You the man!"
Old Oct 7, 2003 | 06:03 PM
M's's Avatar
M's
what if you wanted to run 245/45/17 up front on 17x8's and then 275/40/17 in the rear. then what offset?
thanks and sorry if i am hijacking your thread
Old Oct 7, 2003 | 06:30 PM
neofreak's Avatar
accept no imitations™
+35 in front.
Old Oct 10, 2003 | 10:18 AM
M's's Avatar
M's
TTT
Old Oct 12, 2003 | 01:47 AM
nillahcaz's Avatar
you are missed
what about the back? I want to run 225's all around on mine.
Old Oct 13, 2003 | 07:42 AM
bkapold@aol.com's Avatar
+35mm on all 4 corner is a safe bet for wider wheels... +40mm up front may bump the shock...The wheel won't but some tires will slightly rub the shock/coilover.
remember the smaller the 0ffset number, the more the wheel will stick out...
Old Oct 13, 2003 | 10:48 AM
RarestRX's Avatar
Re: Offset gurus! Need advice on some 17 x 8's and 9's...
Yo,
Anyone? *grin*
Kevin
1989 GTUs "Enquiring minds!"
Old Oct 14, 2003 | 07:18 AM
up front? no way! I don't think that will work for the rears either.
Keep in mind, its not the wheel that rubs, but more the tyre on the shock and or outer fender.
Zinraf
Oct 1, 2015 01:09 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
