help wiring fog lights
Old Oct 2, 2003 | 12:37 PM
jester1341's Avatar
Question help wiring fog lights
i just got my S5 bumper installed and i want to hook up the fog lights. threre are two wires off of the lights and two wires of of the stock switch. i need to know which of the fog light wires is the ground and which is hot? i plan to run 12v to each hot wire and then each grd to the switch then the switch to the chasis.
anyone who has already done this or knows which is grd on the light houseing let me know
thanks,
john
Old Oct 2, 2003 | 01:15 PM
rockshox's Avatar
it doesnt matter which fog light wire you use since incadescent bulbs work in either direction, but the convention is the darker color for ground. dont run the 12v wires directly to a switch as the switch is probably not made for that much current. youll need to use a relay.
Old Oct 2, 2003 | 03:09 PM
DCrosby's Avatar
No it's not Turbo'd
Yup a relay and a voltmeter so you can tell which one's hot which one's ground.... you can even use some cheap 12v bulb from pep buys or something if you can't afford a voltmeter, but that'll just tell you if there's current and not which one's hot... But rockshox, is right usually Dark = (-); Light / White Red etc.. = (+).
You could check with the bulb, if you wire it from one wire to the chassy and it lights you found your + if you don't get anything you found yuur -
Relay is a must, in the switch situation.... the Foglight kit should come with one... or else radio shack sells some automotive relays... (If you need help with how they work ask ! )
-DC
Old Oct 2, 2003 | 09:06 PM
jester1341's Avatar
so its not a grounded switch?? yes please explain the correct way to wire my 89-91 fog lights i have the lights, the brakets and the switch.[i bought the switch and lightrs seprate]
thanks for you help
Old Oct 3, 2003 | 12:09 AM
rockshox's Avatar
ground one wire from the fog light. connect the other fog wire to one of the relay contacts. connect the other contact to positive voltage. connect one side of the relays coil to ground. connect the other coil terminal to the switch. connect the other terminal on the switch to positive voltage that goes off when the car is off.
Old Oct 3, 2003 | 12:22 PM
jester1341's Avatar
hmmmm......sooo should i hook both of the fog lights to the same prong of the relay??
and also.....if at all possible could sumone post a picture diagram, not the brightest here , also......could you use the number of the prong....just so i dont blow anything up....heh
thanks muchly,
john
Old Oct 3, 2003 | 02:38 PM
jester1341's Avatar
bump
inoo im kinda asking for idiot protection, but hey.....i can't blame me......heh <me
Old Oct 3, 2003 | 03:03 PM
DCrosby's Avatar
No it's not Turbo'd
There's a wireing diagram on most relay boxes, or on the houseing itself...
In escence a relay is nothing but an electro-magnet that closes or opens a switch so there's two cuircuits...
1 the switching cuicuit... (Low Voltage) (Trigger) and two the high voltage that you want to send to the device beeing triggered (Fog Lights)
Typically you run a "Hot" + wire from the Battery to the relay and from the relay to whatever you're triggering.... with the relay beeing the interruptor... of current...
then wire the switched voltage... (Find something that gives you current like the voltage from your stereo, but is only on when the car has a key in it...
run that to the switch, and then the relay to trigger the relay, to feed the headlights.... so when you look at it as two "Pipes" of voltage where one triggers the other you'll be allright... the switch you bought just controlls the flow to the relay, that way you can turn the lights on and off even though the key is in the ignition....
BTW a better source for your switched voltage is the ashtray light in an FD, and something similar that is only on when you turn on the headlights... Ignition would be good for daylight running lights if that's what you were going for...
-DC
Old Oct 3, 2003 | 09:37 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
I have a quick question.. Does all FD pre-wired for OEM fog lights?? or do you have to run the wires??
Old Oct 4, 2003 | 12:48 PM
jester1341's Avatar
:edit:
damn server........double post
Old Oct 4, 2003 | 12:53 PM
jester1341's Avatar
first off thanks loads to DCrosby for the explination.
i wanna make sure ive got this down right before i do anything, so i drew up a diagram to the best of my own knowledge,......if its rediculious please let me know. im not an expert at wiring,.........or anywhere near it!
i have a few five prong relays and a three, i should be using the five right?
Old Oct 4, 2003 | 12:59 PM
jester1341's Avatar
oh yeah and i forgot to grd the other side of the fog light.
Old Oct 6, 2003 | 09:02 AM
jester1341's Avatar
anybody?, just tell me the numbers of the contact i should use for each thing?
ino alot of you guys know, just about all of you know more about wiring than me !
Old Oct 7, 2003 | 08:55 PM
jester1341's Avatar
*d0t*.....*d0t*..............*d0t*
anyone.....seriously .......im not clear on how to do this yet, and i don't wanna do it if im not sure.
any help??
Old Oct 8, 2003 | 02:46 AM
rockshox's Avatar
um 12v goes to 30, foglight to 87, switch goes to 86, ground 85. other terminal on the switch goes to 12v. other terminal on the fog light goes to ground
Old Oct 8, 2003 | 08:37 AM
jester1341's Avatar
thanks very much but isnt the stock switch a grounded switch......in other words shouldn't it go from
86-----switch-------grd
from Scott 89t2 i got;
Originally posted by Scott 89t2
you need a 4 or 5 prong standard 12v auto relay.
pin 30 straight to battery (with fuse). pin 87 to fog +. pin 85 to switched 12v (acc). pin 86 to one pin on switch. other pin of switch to ground.
also ground fog lights.
if you don't use a relay you will fry the switch. also this way when you turn off the car. the fog lights will go off by themselfs instead of staying on (no killing battery now)
Old Oct 8, 2003 | 03:13 PM
DCrosby's Avatar
No it's not Turbo'd
Yea that sounds right, sorry I hadn't checked this thread in a while... PM me if you have further questions...
As to the FD question... I'm not sure... I'm almost positive that the PEP had an option for fogs, and all of the touring models i've seen have them / a stock harness... but I'm not sure weather R1/R2 had it as an option .....
fastsaab
Aug 19, 2015 11:42 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
