car has problems starting
Old Sep 30, 2003 | 10:43 PM
hey guy i need help??
my 1981 12a will not start sometimes.can anybody tell me how to narrow the problem.im thinking its ignition switch or starter..the car has a 500 cca battery and clean terminals as well as good ground.how can i test the ignition switch and starter.what the car does is i put the key in the ignition switch and turn it on but all i get is the fuel pump to activate because i can hear it buzzing in the rear.also the cluster does light up when i turn on the ignition but the car doesnt turn over?
please guys help me.i would like to get an idea of what kind of problems i got...
Old Sep 30, 2003 | 11:20 PM
Montic's Avatar
Are the starter side terminals cleana dn grounded good? As well as the wire telling the started when to kick?
Old Sep 30, 2003 | 11:30 PM
RotorMotorDriver's Avatar
Seven Is Coming
When you try and start it what happens? Is there any clicking or anything? Turn on the headlights and try and start it. Do they dim at all? You could check the wires at the starter itself. They should be clean and tight. Also, just triple check your battery connections to make sure they are clean and tight as well. You would be surprised how many strage things have happened just because the battery cables werent good. They can even look just fine, but not work.
~T.J.
Old Sep 30, 2003 | 11:45 PM
im gonna replace wiring
~T.J.
tommorow im gonna replace all my battery wiring .+ and - cables as well as new terminals.good idea since i havent replaced in my 6 years of ownership,also a cheap repair.under 20 dollars.
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
