Electronic Non Sequential Switch?
Old Sep 28, 2003 | 10:50 PM
BicuspiD's Avatar
Infamous...Butcher...
There has to be a way to do this, right? I mean, the second turbo is brought online by a signal to a solenoid, shouldn't you be able to "fake" that signal with an external switch and run it in Non-seq or Sequential, depending on what position the switch is in? I have heard of this mod for the Supras, but has anyone tried it on an FD? A search didn't find me anything
Old Sep 28, 2003 | 11:13 PM
rockshox's Avatar
yeah as far as i know i originated this mod a couple years ago but i have since lost the info. basically you need a 3 pole double throw switch and one position connects the solenoids to the ecus signal and the other position connects 2 solenoids to ground and leaves one open (i think) the same way they would be after 5500 rpm.
Old Sep 28, 2003 | 11:38 PM
gfelber's Avatar
http://www.mantissaracing.com/Mantis...ion_switch.htm
Old Sep 28, 2003 | 11:53 PM
Snook's Avatar
Tony Stewart Killer.
both Puma and I have done gfelber's mods. I especially like the low/high boost switch it's like a free boost controller.
thanks man!
Old Sep 29, 2003 | 02:53 AM
BicuspiD's Avatar
Thnaks so much this is exactly what I was looking for.
On the note where it says boost creep may affect it, this is a non issue if boost creep is a non issue in sequential right?
Old Sep 29, 2003 | 04:34 AM
Mahjik's Avatar
Mr. Links
Boost creep can happen in either setup. Boost spikes are usually eliminated by non-seq (since transition is removed).
Old Sep 29, 2003 | 09:16 AM
BoOsTin FD's Avatar
Powered by** Rotary
does this non-seq to seq switching really works? I mean don't you need to wire the TCA door open when you go to Non-seq? How is this achieved by just taping into ecu?
Old Sep 29, 2003 | 10:02 AM
mks's Avatar
mks
The TCA door is opened/closed by the TCA, which reacts to vaccum and boost being fed to it by the TC solenoids valve. The TC solenoids are controlled by the ECU using electrical signals (how else would it work?), and these signals can be manipulated using a manual switch.
The reason you wire the TCA door open (or remove it) during non-seq conversion is that you remove the TCA.
Old Sep 29, 2003 | 10:59 AM
gfelber's Avatar
Yup.
Gene
Old Sep 29, 2003 | 11:17 AM
Louis M's Avatar
so we won't have to worry about boost spike?
Old Sep 29, 2003 | 12:42 PM
artguy's Avatar
WTB** Very Low Miles 94-95
the part i dont get is that the car has to be tuned properly for each setup...why risk blowing your ***** up by going non seq when you are tuned for seq?
seems silly to me...the fuel map needs of non seq over seq are completely and entirely different.
you should at the very least datalog the runs and see where you are...if you are able to run it without detonating in the first place.
j
poss's Avatar
Slower Traffic Keep Right
I've done the NS switch mod. I'm not a fan of NS, but it is nice to play with some times.
Also, I have a question for those of you that have also performed the mod. On my car if I leave it in NS mode and then shut the car off, when it is restarted and i start to build boost it falls on its face (something to do with the MAP sensor reading). So bascially I have to reset the computer and then it works fine as long as it is shut off in seq mode. Does this happen to anyone else?
Old Sep 29, 2003 | 06:50 PM
BoOsTin FD's Avatar
Powered by** Rotary
hey ISUposs how hard was it to do this? Also at what RPM do you get full boost with non-seq?
Old Sep 29, 2003 | 06:52 PM
BoOsTin FD's Avatar
Powered by** Rotary
damn, i also forgot to ask, what if i Have that PFS ecu. The limitation boost switch says i can't do it if i have PFS ecu but non-seq switch doesn' say anything.
Old Sep 29, 2003 | 08:06 PM
BoOsTin FD's Avatar
Powered by** Rotary
Where can i find that switch too? Looks like a pain-in-the-***-to-find switch.
Old Sep 29, 2003 | 08:15 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Radio Shack I think... I was going to do this mod a while ago and I think that's where I found the switch..
Old Sep 29, 2003 | 08:47 PM
BoOsTin FD's Avatar
Powered by** Rotary
he said in his write up that they don't have it in the radio shack. I'll check anyway. When you look at that diagram for connecting to the switch, does that mean, i have to cut the ecu wire and then ecu side goes to one side and solenoid wire goes to the other side? I'm confused on that part.
Old Sep 29, 2003 | 08:51 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
My bad.. I thought I saw it a Radio Shack... I don't rememberthe part of the instructions you are referring to, but I'll do some digging.
Old Sep 29, 2003 | 10:59 PM
poss's Avatar
I ended up using a relay. Easier to find than a TPDT switch and it allowed me to use a simple toggle switch that could be remotely located.
It's not hard to do, but it does take a little bit of patience since the stock wiring harness is low quality and doesn't have much slack.
Old Sep 30, 2003 | 02:22 PM
BoOsTin FD's Avatar
Powered by** Rotary
can you just tell me, am i suppose to cut those wires and then connect each side to a switch or just tap in?
Old Sep 30, 2003 | 03:33 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
Thanks for the link...helped me out a bunch too!
Old Sep 30, 2003 | 07:30 PM
Zyon13B's Avatar
"I see triangles"
Yes BoOsTin FD, you need to cut the wires and put the switch between.
Old Sep 30, 2003 | 07:57 PM
BoOsTin FD's Avatar
Powered by** Rotary
Thanks a lot man. That's all i needed to know
Old Oct 6, 2003 | 08:38 PM
cmartinp28's Avatar
can this switch be moved remotely? or it has to be right near the ecu?
Old Oct 6, 2003 | 09:47 PM
poss's Avatar
