Help with Radiator Leak!!
Old Sep 28, 2003 | 03:42 PM
4estRX7's Avatar
I just replaced my coolant lines in hopes to stop a coolant leak I have. WRONGO... It did not work. it seems I have a crack of some sort in my radiator. Is this common and can it be fixed or do I need to buy a new radiator?
Old Sep 28, 2003 | 04:02 PM
AMRAAM4's Avatar
twinturboteddy ws my idol
buy a new radiator, if you have the stocker you should have a new one anyhow.
If you put JB weld or something on the current one it may hold, but like the previous idiot did on my car, it eventually wore off after a coolant flush and caused me to be **** out of luck one day.
But it provided a good reason for buying a Fluidyne
Old Sep 28, 2003 | 04:04 PM
RX-7racer88's Avatar
It's Mr. bling 2 you
Yeah you should get a new one like he said. If you do go with a fluidyne or koyo. It will be much better for your FD and will make the motor run cooler too.
connerfd3s
Sep 19, 2015 05:58 PM
The1Sun
Sep 15, 2015 04:45 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:04 AM
