How do you remove the actual A/c pully?
Old Sep 27, 2003 | 03:11 AM
Rx-7$4$me's Avatar
Im having problems with it.
Also the two main AC lines by the intakes, how can you possibly get them off without removing like everything.
Old Sep 27, 2003 | 06:24 AM
DamonB's Avatar
To get the a/c pulley/clutch off you have to first remove the nut in the center. Then you have to get an a/c clutch puller (similar to a gear puller) to press the pulley off.
Old Sep 27, 2003 | 03:19 PM
Rx-7$4$me's Avatar
IS that how you get the whole unit off? Im just eliminating it
Old Sep 28, 2003 | 04:47 PM
Rx-7$4$me's Avatar
bmp
Old Sep 28, 2003 | 04:54 PM
AMRAAM4's Avatar
twinturboteddy ws my idol
My A/C pulley has a slight bend on its lip, which thus has frayed the end of the belt. I don't like the frayed belt, so I just got the shorter belt and didn't bother to hook it around the A/C pulley. Screw it, I don't use the A/C and it just draws on the engine more anyhow.
Old Sep 28, 2003 | 04:55 PM
Trexthe3rd's Avatar
Are you trying to remove the ac compressor or just the pulley? If its just the pulley your asking about, the easiest way is with an impact wrench.
Old Sep 28, 2003 | 05:53 PM
Rx-7$4$me's Avatar
the compressor
Old Sep 28, 2003 | 06:01 PM
Rx-7$4$me's Avatar
the compressor
Old Sep 28, 2003 | 07:52 PM
DamonB's Avatar
Originally posted by Rx-7$4$me
the compressor
Drain the a/c and disconnect the two hard lines from the back of the compressor. Remove the mounting bolts on the front of the compressor. The compressor will fall off.
ZacMan
Sep 19, 2015 09:20 PM
risingsunroof82
Sep 7, 2015 01:11 PM
