Help- Car hesitation
Old Sep 26, 2003 | 08:55 PM
Bob Kennedy's Avatar
Thanks for reading-
I had a car fire back in Feb with my 93 rx7 touring. (no mods) After 7k and 3 months I finally got my car back. Then 3-4 days later the car began hesitation. For instance the car wouldn't go over 100mph. Also sometimes when you put your foot down on the accelerator, the car would lack any power and take 2-3-4-5 seconds before it would accelerate. It seems to idle ok, although rough idle. But it always idled rough (before the fire).
Can you offer any suggestions on what could be the problem? A local shop had the car for a week or so but couldn't find the problem. Then the dealer had the car and ran a compression test on it. They said the compression was fine. Spark plugs are new so thats not the problem. The dealer said that they'd have to spend many hrs going thru the vacuum lines, exhaust etc just to TRY to identify the problem.
Any advise or suggestions would be greatly appreciated.
Thanks
BOB
rj_kennedy@netzero.net
Old Sep 26, 2003 | 09:15 PM
rynberg's Avatar
Is the car still 100% stock? If so, your pre-cat is probably clogged, which may also have taken out your main cat.
Do you have a boost gauge? If so, what are your readings? If not, get one. If you don't want to install one in your interior, get a cheap mechanical one and get a piece of vacuum line long enough to run it from your intake manifold to the interior of your car. You can at least trouble shoot boost issues this way.
Old Sep 28, 2003 | 08:58 PM
Some more info
The car seems to run ok up to 5k rpms. Then no power and need to up shift to get more power. BTW- car has 115k miles on it.
Old Sep 28, 2003 | 09:15 PM
Mahjik's Avatar
Mr. Links
https://www.rx7club.com/forum/showth...hreadid=206277
Did you ever get a boost gauge?
fastrx7man
33
Sep 2, 2015 09:42 PM
Feffman
Midwest RX-7 Forum
Sep 1, 2015 07:30 AM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
