Misfire maybe?
Old Sep 26, 2003 | 09:18 AM
XSTransAm's Avatar
Ee / Cpe
Misfire maybe?
With my new haltech in the car runs great MOST of the time, But sometimes like this morning it has a couple of problems... When i boosted to 14 psi this morning the car made a pop noise at around 5000 rpms and stuttered, and i saw the tach drop abot 500rpms for a second... then it keeps pulling hard... I have the haltech set up to run between 10.8-11.2:1 afr throughout boost.... Does this problem sound like im just misfiring...
If so what could i do? i alreayd have new ngk plug wires on my desk to intall, and i put new sparkers in it about 7000 miles ago... Time for coils maybe?
i never had this problem with my stock ecu, but then again i was never boosting to 14psi with my stock ecu either
Old Sep 26, 2003 | 09:25 AM
Mahjik's Avatar
Mr. Links
I'm assuming the car was at operating temps when this happened?
If so, I would try new plug wires first (along with checking your grounding). I switched to Magnecor wires about 2 years ago and they helped in my rpm breakup/hesistation.
After that, you might want to look into some of the ignition products like the HKS or Ignition Solutions.
Old Sep 26, 2003 | 09:35 AM
XSTransAm's Avatar
Ee / Cpe
yeah, normal operating temps... i wouldent even think of boosting otherwise... hmm, i guess ill try the wires i have here first... then ground the **** out of it... if all that dosent work ill cut my meal plan and buy new coils
thanks mahjik!
Old Sep 26, 2003 | 09:40 AM
Mahjik's Avatar
Mr. Links
You shouldn't need new coils unless there is a problem with yours. Typically you only need an ignition amplifier to help get a better spark.
Old Sep 26, 2003 | 09:42 AM
XSTransAm's Avatar
Ee / Cpe
oh.... i have a msd digital 6 plus box sitting in my trans am collecting dust... would that work with the haltech?
Old Sep 26, 2003 | 09:46 AM
Mahjik's Avatar
Mr. Links
I don't see why the Haltech would have a problem with it, however I'm no Haltech expert.
I believe "rotorbrain" is running that MSD system. You might PM him about it.
alphawolff
Nov 17, 2015 05:57 PM
R7rexy
19
Sep 2, 2015 10:24 AM
rxmiles
Aug 24, 2015 02:07 PM
Wolf_
Aug 11, 2015 04:23 PM
