remapped ecu
Old Sep 25, 2003 | 12:01 AM
cmartinp28's Avatar
remapped ecu
just out of curiosity......
how do you tell a remapped ecu from a stock ecu
for example, pettit and m2
Old Sep 25, 2003 | 12:20 AM
rynberg's Avatar
They should have a sticker on the case. Inside the case will be additional daughterboards.
Old Sep 25, 2003 | 12:23 AM
cmartinp28's Avatar
so in other words...... openning up the case and looking inside is the only way to find out?
Old Sep 25, 2003 | 12:27 AM
bureau_c's Avatar
Its the only way to find out for sure. Like rynberg said, usually there is a sticker on the outside case...but if not and you have reason to think it is remapped, or if there is a sticker but you question its validity, then you're right...you have to take off the cover, remove the screws that hold the main board, and fold it back (the two boards are connected to one another via a flexible cable) to see if the daughter board is present.
jds
Old Sep 25, 2003 | 12:34 AM
cmartinp28's Avatar
jds, i can see in your sig that you have a remapped ecu? who was it made of.... and did you ever open it?
Old Sep 25, 2003 | 12:50 AM
cmartinp28's Avatar
did what you said.... but i didnt wanna force it open.... and this is what i saw
remapped? or stock?
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
