Probe Turbo fit into RX-7 ??
Old Sep 23, 2003 | 02:14 PM
Gui-Gui GT's Avatar
Newbie
I have a 89 Probe GT Turbo with the 2.2L engine and the turbo work good! The body was junk! I want to buy a 87 RX-7 non turbo ... does the turbo fit ??? That a mazda motor in probe ...
Old Sep 23, 2003 | 02:21 PM
carx7's Avatar
Probalby not, cause the Rx7 is rotary. Plus the NA rx7 driveline will not support the power that the turbo driveline will support. Plus that probe turbo is probalby a little T3... which may be smaller than even a stock TII turbo. The NA motors are higher compression than you would ideally want for turbo.........
You would need a turbo computer since the NA one can't deal with positive manifold pressure....
If you want a turbo Rx7, buy a TII... unless you have tons of time and access to a turbo car anyway for parts (rear end, half shafts, transmission, etc, etc, etc) you don't want to mess with putting a turbo on the NA motor.
Old Sep 23, 2003 | 03:06 PM
DaleClark's Avatar
RX-7 Bad Ass
Also, the turbo is WAY too small - heck, Probe owners get stock TurboII turbos as upgrades!
Dale
Old Sep 23, 2003 | 04:01 PM
Aaron Cake's Avatar
Engine, Not Motor
Uh huh.....You could make it fit with a custom manifold, but you wouldn't really want to do this...see below...
Your proof of this is?
In fact, it's probably smaller then that. The Probe turbos are TINY. The entire turbo would probably fit in the hot side of the Hitachi unit on the RX-7 (which, incidentally, is basically a large T3).
And your proof of this is?
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
