Help please
Old Sep 22, 2003 | 11:48 PM
Renegade_07's Avatar
THINK
Help please
hey i have a 1985 gsl 12a i was driving today and i noticed a hesitation at 2000 rpm which seems to cause it to lose power where should i start to look to solve my problem thanks
Alvin
Old Sep 23, 2003 | 06:40 AM
Rx7carl's Avatar
Airflow is my life
More info please. Will it accelerate past 2000? Is it running ok once you pass 2000?
Old Sep 23, 2003 | 09:07 AM
Metallic_rock's Avatar
Ride 'n Style
#1. fuel filter
#2. Air Filter, spark plugs, wires, cap, rotor
Pretty much, just give it a good tune up. If that doesn't work, then give us more info on exactly what it's doing.
Old Sep 23, 2003 | 04:25 PM
THINK
hey thanks for replying
yeah once past 2000 it runs flawlessly and i have changed fuel oil and air filters the distributer cap was changed and the sprak plugs were just wirebrushed and cleaned and regapped also i just did a motor oil change
Old Sep 23, 2003 | 09:55 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
It's possible that the secondaries are adjusted a little wierd, and they are starting to kick open at that point. I don't however know how to adjust them other than if you were to convert to mechanical secondaries. I simply haven't looked into that issue.
Brian Heston
Old Sep 23, 2003 | 10:01 PM
Rx7carl's Avatar
Airflow is my life
Is it all the time? or just when its cold? OR after warmup?
Old Sep 24, 2003 | 02:56 AM
THINK
thanks
hey brian thanks for a good starting point i will look into that and carl yeah its all the time even after warm up
Old Sep 24, 2003 | 01:56 PM
My 7 has kinda the same slight stall at about 2500 - 2700 depending on the load. I think it's just when the secondaries are kicking open. But for the way I drive that's about right for me. The only way around it for me is to creep past that point, or just flat out punch it past that point, anything else and I feel the hesitation. 2000 would be a bit low and annoying though.
Let me know if you stumble on a way to adjust them without switching to mechanicals though.
Later,
Brian Heston
Old Sep 24, 2003 | 03:24 PM
Rx7carl's Avatar
Airflow is my life
Sounds like you guys may actually have varnished/gummed up transition circuts. Run a bottle of fuel system cleaner for the next few tanks of gas and see if that helps.
