Hesitation below 3800 range
Old Sep 22, 2003 | 11:15 PM
I've been having this problem for a while. My car doesn't like to rev until it gets to around 3800RPM. Once I get past there, it revs fine, but almost anywhere below there, it wants to hesitate severely, along with the occasional backfire. I think it may be a vac leak, but I'm not sure and want to see if anyone else has any ideas. Also, just in case, is there anywhere I could maybe get a set of all the vac lines, seeing as if one is going, I'm probably about due for the rest of them to go. Thanks.
Old Sep 22, 2003 | 11:28 PM
kllntyme's Avatar
Legend in my Spare Time
Just replace all vacuum lines with silicone. Buy the small guage by the foot, because it takes alot.
I believe the rx7store sells a kit that has all the silicone lines you need.
As for the hesitation: Check to see if your aux ports are working. If one has stuck open that can do it. I had one stuck closed. After that you may want to pull your primary injectors and get them tested or cleaned.
Old Sep 23, 2003 | 02:08 AM
I know the aux. ports are fine, since the car acts fine above 3800 rpms. I forgot to mention that the car will sometimes begin to act normally after I've driven for about 15 minutes or so, although it eventually hesitates again.
Edit: realized you said one port may be stuck open I'll check into that
Old Sep 23, 2003 | 02:26 AM
adamlewis's Avatar
Back from teh deadly!
I thought it might be a primary injector problem. I know T2's have the problem ( only they hesitate after 3500~3800...not before ) and all you have to do is add an extra ground to a certain pin on the ECU.
rgordon1979
40
Mar 15, 2022 12:04 PM
Sethix
Nov 3, 2017 11:48 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
lnlreaper
Sep 27, 2015 09:59 AM
