Wiper Arms
Old Sep 22, 2003 | 03:22 PM
sectachrome's Avatar
pistons=teh suck
Wiper Arms
im trying to take off my wiper arms so i can sand the rust off and paint them. i took the nuts off and sprayed some wd40 on the thread but i cant get them to come off. please help!
Old Sep 22, 2003 | 03:28 PM
Ryde _Or_Die's Avatar
I just did this. You don't need any WD-40 more than likely. Just pull the arm upand use a flathead on the backside prying it up.
Old Sep 22, 2003 | 03:29 PM
Oh and I used some stuff that turns rust into black primer first, then used some rustoleum, then clear coat. I had bad experiences with thinking I sanded all the rust away and it just came back.
Old Sep 22, 2003 | 03:35 PM
pistons=teh suck
ok thanks. im gonna put the rustoleum primer stuff on, then gloss black rustoleum.
Old Sep 22, 2003 | 03:54 PM
pistons=teh suck
alright i just tried the screwdriver thing and i cant get them off. i stuck it under neath the arm right next to the threaded part (whatever its called, the thing the arm is attached with) and pryed that mother with the handle pointing towards the engine. any other suggestions?
Old Sep 22, 2003 | 03:56 PM
I dunno man, I just did mine this weekend and had no problems. They are only sitting on the threaded "rods." I thought they were stuck too, but its just a bit of wiggling to it. I pulled the arms away from the windshield and pulled up some. Then tried putting the flathead on the other side at the same time and they came right off.
Old Sep 22, 2003 | 04:43 PM
Jodoolin's Avatar
Once in they rest at an angle to the thread. Had the same problem till I figure what was happening. Make sure you lift flat up against the downward tilt then lift straight up. Pull the wiper to the standing upward position. Maybe try vice grip padded with a rag to pull it off.
Old Sep 22, 2003 | 05:31 PM
pistons=teh suck
thanks for your help man. i just had to push it the other way a bit because i was trying to take it off at an angle, then it came right off.
Old Sep 22, 2003 | 10:52 PM
hondahater's Avatar
spending too much money..
Thats funny I just did the same thing yesterday they turned out looking great I didn't know anyone else had done this. First sanded them with a rotor tool then primered them with 2 coats then painted them with three looks absolutley great. No need to buy new ones.
Old Sep 22, 2003 | 10:54 PM
hondahater's Avatar
ps. rear windshield was differant I just stuck an old towel underneith it and sprayed it right on the car and again looks amazing.
Old Sep 22, 2003 | 11:11 PM
BLUE TII's Avatar
Rotary Motoring
My wipers took a lot of wiggling to get them off the splined shafts.
I used a black epoxy spray paint that is made to touch up appliance powdercoat. Worked very well!
Old Sep 22, 2003 | 11:29 PM
I did the same with my rear one too Man does it change the overall appearance of the car IMO.
Old Sep 22, 2003 | 11:32 PM
hondahater's Avatar
oh yeah cheapest thing I have ever done to the car to make it look just that much better.
Old Sep 23, 2003 | 02:03 PM
pistons=teh suck
i put a coat of rustoleum primer on it, and im planning on picking up some rustoleum flat black today. would spray paint be better?
Old Sep 23, 2003 | 02:13 PM
Thats what I used, rustoleum flat black spray, then clearcoat.
Old Sep 23, 2003 | 03:29 PM
pistons=teh suck
why clearcoat? wont it make it shiny?
Old Sep 23, 2003 | 03:41 PM
It didn't make mine very shiny. Just look like they are brand new. I clearcoat everything I paint, just so it will hold up better.
pfsantos
Sep 30, 2015 01:29 PM
WANKfactor
Sep 29, 2015 01:14 PM
